Pocket GPS World :: View topic - How to reset a Belkin (Fortuna Clip-on)
burdell1
PostPosted: Sat Sep 02, 2006 2:45 pm    Post subject: How to reset a Belkin (Fortuna Clip-on) Reply with quote
I have the Belkin bluetooth GPS, but it is the same as the Fortuna clip-on. However, mine no longer turns on. I tried hooking it up directly to the power and nothing. I took out the battery and connected it directly to the power cable and the power light would come on for a split second, then nothing. How do you reset it? i thought you had to take out the battery for a few hours and then it would reset, but it hasn't helped. Is there another way to reset it?
c2R
PostPosted: Sun Sep 03, 2006 5:24 pm    Post subject: Reply with quote
Does the battery not supply 3.7v and the USB Power Supply 5V? That could be a problem?
It should power up when connected to the power supply irrespective of there being a battery in it or not... Also, try testing the battery with a multimeter to see if it is charged.
Chris
22.051 (01 May 24)
