Pocket GPS World :: View topic - Ball Adapter for the Nuvi Auto Mount
cfujii
PostPosted: Sat Aug 26, 2006 6:22 pm    Post subject: Ball Adapter for the Nuvi Auto Mount Reply with quote
I have a Nuvi 360 that I'm trying to mount to a car floor/seat bolt snake style mount.
The issue is that the RAM mount, that came with the car floor/seat bolt mount blocks access to the USB. I would like to use the Garmin Auto mount but it has a 17mm ball socket.
What I need is a 17mm ball that has a 9mm (.358") round stem that protrudes from the ball. The 9mm stem should protrude at least 18mm (.702") that would fit into the opening of the snake and would be secured by an screw on the side of the opening of the snake mount. The 18mm extension can be longer to provide wiggle room for the Nuvi Auto mount.
PostPosted: Sat Aug 26, 2006 6:42 pm    Post subject: Reply with quote
Welcome to the forum, have a look at THIS site Mr Gonzalles (probably not spelt the name correctly Embarassed ) but he might be able to assist in what you require - Mike
cfujii
PostPosted: Sat Aug 26, 2006 8:05 pm    Post subject: Ball Adapter for the Nuvi Auto Mount Reply with quote
Thanks, I order two 17mm balls. Too bad he is going out of business.
Mr_Gonzales
PostPosted: Fri Dec 12, 2008 10:12 pm    Post subject: Reply with quote
Back in business again, at least for the balls.
Website is back up at http://www.mounts.pwp.blueyonder.co.uk/
21.021 (01 Feb 23)
