rajah Occasional Visitor
Posted: Sat Aug 05, 2006 10:50 pm Post subject: Updates to Camera |
For the last three months I've submitted a change to the following camera on the A449 into Wolverhampton
The database shows Gatso:2759 as being in a 40mph limit when in fact it's in a 30mph limit.
I see in the latest database it's still showing as a 40mph!
How many months/attempts does it normally take to get such an obvious change made?
Roy |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sun Aug 06, 2006 2:56 pm Post subject: |
It has to be verified before a change is made, maybe nobody esle has bothered to report it. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Sun Aug 06, 2006 8:34 pm Post subject: |
Interestingly the camera appears to have been correctly added to the 30mph database in January of this year, and then for some reason moved to the 40mph database in the February release.
Presumably someone must have verified it correctly in January, then incorrectly in February, or there's been a simple human error made between the January and February databases.
Just extremely frustrating to have to keep converting the ov2 files to xls, modify them and convert them back to correct the situation. |
Posted: Sun Aug 06, 2006 8:56 pm Post subject: |
Download and install POIEdit onto your home PC, you can then cut/ paste and edit the POI files directly without having to convert to Excel - it just makes life a little bit easier - Mike |
Posted: Sun Aug 06, 2006 10:24 pm Post subject: |
Thanks for the tip.
Will do as you suggest. |
JockTamsonsBairn Lifetime Member
Posted: Sun Aug 06, 2006 11:33 pm Post subject: |
rajah wrote: | Just extremely frustrating to have to keep converting the ov2 files to xls, modify them and convert them back to correct the situation. | What device are you using? It may be possible to move the POI from one group to another on the device. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Fri Aug 11, 2006 12:46 am Post subject: |
Using Mitac Mio P350.
Roy |
Posted: Fri Aug 11, 2006 12:53 pm Post subject: |
rajah wrote: | Hi
Roy | What software? _________________ Jock
Posted: Sat Aug 12, 2006 12:50 am Post subject: |
TomTom Navigator 5.2 |
Posted: Sat Aug 12, 2006 9:49 pm Post subject: |
rajah wrote: | TomTom Navigator 5.2 | Browse Map and find the POI, then Add as POI, then select the Category, then amend the name and tap Done. Then go back and remove it from the original category.
While on this subject can someone tell me what the "clover leaf" icon in Browse Map (i.e. not Options, Magnifying Glass nor Done) is supposed to represent and what do we call it? _________________ Jock
Posted: Sat Aug 12, 2006 9:59 pm Post subject: |
I use it mainly to Centre on map. but you can use it to Navigate there, Find nearby POI, Add as favourite, Add a POI or travel via. _________________ Formerly known as Lost_Property
Posted: Sat Aug 12, 2006 10:00 pm Post subject: |
BGF wrote: | While on this subject can someone tell me what the "clover leaf" icon in Browse Map is supposed to represent and what do we call it? | It brings up a menu called "Cursor Position" so I guess its simply this, if when you are in browse map and tap the screen the same sybol is displayed on the map at the point of contact, pressing this "clover leaf" icon brings up another menu from which you can select "Nav There", "Find nearby POI", Add as Favorite", "Add as POI" or "Centre Map" this later function is one I find quite handy when finding somewhere located in an overseas location, quite often the address is either spelt incorrectly or in an incompatable format, this option can be useful in this situation to zoom in for closer inspection / re-use then selecting the "Nav There" option to get you there - Mike |
I hadn't finished. I don't know if you've noticed the blue arrow icon, top right, tap on this to re-centre your position if you have been browsing the map. _________________ Formerly known as Lost_Property
Posted: Sat Aug 12, 2006 10:07 pm Post subject: |
Lost_Property wrote: | I hadn't finished. I don't know if you've noticed the blue arrow icon, top right, tap on this to re-centre your position if you have been browsing the map. | This centres the map to the current GPS position, which is different to center map to a screen tap, if you have no GPS position then tapping the arrow (top Right) does nothing of any real note - Mike |
Posted: Sat Aug 12, 2006 10:36 pm Post subject: |
Quote: | This centres the map to the current GPS position, which is different to center map to a screen tap, if you have no GPS position then tapping the arrow (top Right) does nothing of any real note - Mike
I've only ever used it if I have a lock or using Advanced planning. Without a lock it shows 'No usable locations near GPS position'. so as you say, 'it does nothing'. _________________ Formerly known as Lost_Property
