linknet Frequent Visitor
Posted: Sun Jul 16, 2006 7:39 pm Post subject: |
yebaws wrote: | Thanks again!
Anybody who has managed to download the most recent map, I'd be very grateful of they could email it to me. Please pm me and I'll give you my address. |
I've pm'd you.
Roger |
yebaws Occasional Visitor
Posted: Sun Jul 16, 2006 9:36 pm Post subject: |
Roger,
Don't know what's going on with the pm's - I haven't got yours and you obviously didn't get mine..
Don't like doing this (maybe I can get a moderator to remove it later), but here's my email (please remove *'s and substitute "at"):
pocketgpsworld****at*****corriechoille**.**co.**uk
Thank,
Justin |
Posted: Sun Jul 16, 2006 10:04 pm Post subject: |
Justin
The pm's are not working.
This will probably be locked by the moderators but the file is normally available for free download to anyone so here goes:
Part 1:
Part 2:
Download both and then unzip with WinRAR.
Roger
Please do not link to dubious/ illegal sofware/ map downloads in the forum thankyou - MikeAlder |
Posted: Mon Jul 17, 2006 4:58 pm Post subject: |
linknet wrote: | The map out of date message is simply trying to create revenue and get you to update.
If you don't like it simply edit this line in the prefs.ini file:
NoticeForUpdate = 1
Change to:
NoticeForUpdate = 0
You can also make the same change to the defaults.ini file then if you restore the default settings you will still have the modification.
Regards
Roger |
Roger,
where is the prefs.ini file located?
Thanks,
Justin |
Posted: Mon Jul 17, 2006 6:22 pm Post subject: |
Just a tip someone might be watching Mike |
Posted: Mon Jul 17, 2006 7:11 pm Post subject: |
Quote: | where is the prefs.ini file located? |
Should be in the 'NAVIGON\MobileNavigator' Folder.
Roger |
Posted: Mon Jul 17, 2006 7:16 pm Post subject: |
Not from Navigon - They don't even seem to have enough time to keep their own site in order and don't reply to emails. As Roger said - the updated map files *should* be freely available for all to download if their upload link was working, although I understand you removing the download links if that's forum regs. Unfortunately the pm's weren't working. The map files are worthless without the activation code purchased from navigon or software that is already activated (which is what I have). As for modifying the prefs file, I can't see a problem with modifying a file that is installed on you own machine, for your own use..
mikealder, could you remove my email address from earlier post to avoid spamming? Thanks |
Posted: Mon Jul 17, 2006 7:19 pm Post subject: |
linknet wrote: | Quote: | where is the prefs.ini file located? |
Roger |
Thanks, found it. |
Posted: Mon Jul 17, 2006 7:25 pm Post subject: |
managed to find the NoticeForUpdate line, but not the showsecuhint line or anything that looks like it would do the same job... |
Posted: Mon Jul 17, 2006 7:34 pm Post subject: |
yebaws wrote: | managed to find the NoticeForUpdate line, but not the showsecuhint line or anything that looks like it would do the same job... |
Just add the line to the same [MobNav] section.
Roger |
Posted: Mon Jul 17, 2006 7:36 pm Post subject: |
Somebody may be watching! Navigon have fixed their download link! I'm downloading the new map file. Thanks for all your help Roger, but I should be OK now... Just hope I can get it installed
Justin |
jedidaz Occasional Visitor
Posted: Sat Aug 19, 2006 10:09 am Post subject: |
I have finally downloaded map and it works fine. Only thing is no noticable difference. I know quite a few new streets and roundabouts in my area but no changes at all. What a waste of effort. |
Posted: Sat Aug 19, 2006 10:19 am Post subject: |
jedidaz wrote: | I have finally downloaded map and it works fine. Only thing is no noticable difference. I know quite a few new streets and roundabouts in my area but no changes at all. What a waste of effort. |
They have added road speed limit data to bring it into line with the continental europe maps, as far as I am aware that is the only change.
Roger |
