Pocket GPS World :: View topic - POI or Favourit Catagories.
Svengali_uk
PostPosted: Mon Jun 26, 2006 8:45 am    Post subject: POI or Favourit Catagories. Reply with quote
I have created two catagories of POIs - Cameras and Viewpoints.
I would like to transfer my existing camera data into the new Camera catagory - is this possible?
I have been given a folder full of POI files from a friend, showing photographic viewpoints in the Lake District. Is it possible to load these files so that they appear in the Viewpoint catagory - or even better, Favourites?
PostPosted: Mon Jun 26, 2006 11:06 am    Post subject: Reply with quote
Ojn the device itself, you can do it one by one.
For example to transfer from one POI category to another, you just go into manage POI, select the category you want to add into, tap "Add POI" and on the next screen select "POI". Then just find the one you want.
Obvoiusly this will get a bit tedious if you have hundreds to transfer, but is probably the quickest method for just a few.
To do it the techy way, do a search on here (or Google) for "POI Edit" which can import and merge categories.
tonys66
PostPosted: Mon Jun 26, 2006 5:13 pm    Post subject: Reply with quote
You can get poi edit from here http://www.poiedit.com/index.htm
Svengali_uk
PostPosted: Mon Jun 26, 2006 6:08 pm    Post subject: POIEDIT transfers Reply with quote
I have downloaded & run POIEDIT, and created two files/catagories.
However, I cannot find how to ensure that they end up in the correct catagory lists of my TTGO
22.053 (15 May 24)
