Pocket GPS World :: View topic - Extended Battery killed My 2210
oddsock
PostPosted: Tue Jun 20, 2006 7:03 pm    Post subject: Extended Battery killed My 2210 Reply with quote
have just bought an extended battery for my 2 year old 2210.I loaded the cd which updates the ipaq's ROM to accept the new battery ..the first screen came up on the PC saying it was verifing information about ipaq and the ipaq's screen displayed a screen saying the Rom version I have ..V1.11 then everything froze ,PC and ipaq ..the ipaq has stayed frozen and will not soft or hard reset it just displays the same frozen screen until the battery is removed and active sync will no longer work .I called Hp support and they told me it was a chargeable repair Evil or Very Mad has anyone a solution or plan of action??
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
alix776
PostPosted: Tue Jun 20, 2006 7:09 pm    Post subject: Reply with quote
if it wasnt an hp product then it will be chargeable repair just ask for a estimate
try leaveing the battery out over night then put the original battery back in and see if it will work it might be worth replacing the 2210 with a newer model
device Lumia 950 xl
oddsock
PostPosted: Tue Jun 20, 2006 7:28 pm    Post subject: Reply with quote
Thanks I'll try that with the battery. BTW it was a genuine Hp battery and ROM upgrade CD from PC World. As far as I can tell the upgrade had not started it was just Querying the ipaq to see what Rom version it had because I looked in the ipaq folder it had put on PC and an .exe file in there gave a warning that the Rom was to be changed and to make sure all data was backed up and that had not been displayed during the acive sync conection .
Garmin Quest
CharlieG
PostPosted: Tue Jun 20, 2006 8:37 pm    Post subject: Extended battery for iPaq 2210 Reply with quote
I have also just bought one of these from Computer World. Following best practice I backed up everything before I started then did the install. Everything went through perfectly. I then did an after backup and everything is hunky dory.
Charlie Gregory
iPaq 2210, Velcro mount, Viking 1GB SD, 2GB Microdrive,
4GB Kingston Elite Pro CF,TomTom 5 v5.21, Maps of Europe,
Dest 6, Maps of Europe, Memory Map Navigator (Europe Edition)
GlobalSat SDI0 SD-501 GPS, BT GPS
TT BT GPS, Inforad
oddsock
PostPosted: Tue Jun 20, 2006 8:49 pm    Post subject: Reply with quote
So can you confirm that you had to agree to the Rom upgrade before any changes were made and what Rom version you now have??
Garmin Quest
bblz
PostPosted: Wed Jun 21, 2006 2:34 am    Post subject: Reply with quote
I've just bought one of these batteries, I must admit that not being the techie type I shied away from the ROM upgrade and just threw the battery on without it, it seems to be working ok. What does the ROM upgrade add - am I unlikely to get the full benefit from the extended battery without it?
It's definitely an official HP item though so I think you can definitely get a free repair out of it.
lbendlin
PostPosted: Wed Jun 21, 2006 4:45 am    Post subject: Reply with quote
Without the ROM upgrade the device will not know that there now is a bigger capacity battery in, and will only charge the battery up to the original capacity. This is rather undesirable if you want to extend the life of the battery.
Lutz
TomTom/TeleAtlas NAVTEQ
oddsock
PostPosted: Wed Jun 21, 2006 8:17 am    Post subject: Reply with quote
Is it possible that the Rom upgrade is only responsilbe for the reporting /use of the battery because you can charge it via the two contacts jack in the side of it when it is not attatched to the ipaq as well as through the multi pin plug in the bottom of the ipaq... If the ipaq already has Rom 1.10 I'm not sure that the update from the CD that came with the battery is actually needed as the Readme file with the specs are the same one that is with the Rom 1.10 from Hp support which I had upgraded to two years ago..If anyone wants to check.. the Rom on the CD is : 1.10.07 ENG. and compare it with what they have now it may save any probs .... Settings/System/Asset viewer/version.
Garmin Quest
oddsock
PostPosted: Wed Jun 21, 2006 9:19 am    Post subject: Reply with quote
PHEW!!! after hours on google and a few grey hairs I have resurrected my 2210 :D :D :D ....I discovered that the screen it was locked into was the Bootloader one and active sync could not communicate it.
I fixed the problem by connecting the ipaq in its cradle via USB to a computer without A sync installed on it and executed the original ipaq Rom downloaded from Hp support...I then restored my files from the Sprite Backup file stored on the CF card..After this proceedure I am now 100% certain that that I did not tick the box to start a Rom upgrade off the Cd ( Both Roms are the same so no need to upgrade )that came with the battery so dont know why it froze the way it did .I am not to happy that the guy from Hp support did not recognize the symptoms after the detailed conversation we had on the phone and was willing to take 170 off me to boot.
Garmin Quest
CharlieG
PostPosted: Wed Jun 21, 2006 2:20 pm    Post subject: Extended battery. Reply with quote
Sorry for the delay in replying.
I honestly can't remember if I was asked to confirm that I wanted toagree to the ROM upgrade, I did anywayso would have selected Yes.
I am now on
Product Revision Level A01
ROM Date 03/01/04
ROM Version 1.10.07 ENG
OS Version Windows CE 4.20
Bootstrap Version 0.36
Bootloader Version 1.08
Charlie Gregory
TT BT GPS, Inforad
bblz
PostPosted: Wed Jun 21, 2006 9:06 pm    Post subject: Reply with quote
Thanks Dave, just checked my 2210 and the ROM is shown as Revision 1.10.07 ENG dated 03/01/04. Phew, seems I already have it.
21.021 (01 Feb 23)
Terms & Privacy
