Pocket GPS World :: View topic - Spain and UK Maps question
colinra
PostPosted: Thu Jun 15, 2006 11:26 pm    Post subject: Spain and UK Maps question Reply with quote
Ok, I have recently purchaced a TT One and I am new to this Sat nav stuff.
Can I download the additional map from TT and buy a bigger SD card then copy all the files over onto one card and have working maps of Spain and the UK at the same time??
sgould
PostPosted: Fri Jun 16, 2006 12:07 am    Post subject: Reply with quote
Yes!!
But you will need to use the Change Prefs/Manage Maps/Switch maps to change between the two maps.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Border_Collie
PostPosted: Fri Jun 16, 2006 12:24 am    Post subject: Reply with quote
Remember each map download is about €60, whereas the Full European mapping is €120. So if you plan, for example, to include the French map at a later date, it would be better to get the Full European mapping.
colinra
PostPosted: Fri Jun 16, 2006 12:25 am    Post subject: Reply with quote
fantastic. :D
thanks for your help
Border_Collie
PostPosted: Fri Jun 16, 2006 12:26 am    Post subject: Reply with quote
Unless the Spain plus map is loaded when you can select the Spanish map before leaving the UK, set the detination and be guided over the Major Roads of Europe through GB and France and on arrival at the Spanish boarder have Street level without a switch. Smile
DaveO1959
PostPosted: Sat Jun 17, 2006 1:07 am    Post subject: Reply with quote
I have the standard GB maps that came with my ONE and the France Plus maps on a seperate SD card and want to put them on one SD card as well.
Am I right to assume I copy the entire contents of the orignal SD card that came with the ONE onto the new SD card and then just the France_Plus-Map folder off the French map card?
Thanks,
PostPosted: Sat Jun 17, 2006 7:37 am    Post subject: Reply with quote
Yes. Just make sure you Copy it to the Root of the SD Card.
DaveO1959
PostPosted: Sat Jun 17, 2006 2:01 pm    Post subject: Reply with quote
Great. Thanks very much. Thumbs Up
