Pocket GPS World :: View topic - "GPS not found" after restarting iPaq +Destinator3
rajivmehra
PostPosted: Fri May 19, 2006 6:36 pm    Post subject: "GPS not found" after restarting iPaq +Destinator3 Reply with quote
Hi all,
I just bought a BT GPS reciever - an OnCourse BT from buygpsnow. I have a iPaq 3955 with a Belkin CF BT card running Destinator 3.0.25.
Everytime I restart the iPaq (after turning it off while Destinator is running) I get the message "GPS not found" . Everything works fine if I restart destinator.
I did not have this problem when I was using the old mouse type GPS.
What can I do ?
-Rajiv
Pogi
PostPosted: Fri Jun 23, 2006 7:32 am    Post subject: Reply with quote
I noticed the same with my CF and BT gps receiver. I believe when you turn your Ipaq off, you cut all power hence it loses the pairing with your gps receiver.
I assumed you don't expect Destinator to still be connected to your gps receiver once you turn off your Ipaq.
Guess it works fine for a GPS mouse.
rajivmehra
PostPosted: Fri Jun 23, 2006 12:59 pm    Post subject: Reply with quote
Yes, it works fine with a mouse GPS...but here is the rub....
I loaded Mapopolis on the ipaq. When the ipaq is powered on...mapopolis is intelligent enough to try to reconnect to the GPS !
Destinator is not and it just says "GPS not found".
This sucks!
22.052 (08 May 24)
