Pocket GPS World :: View topic - How do I rollback to 2.70?
Alang
PostPosted: Sat May 06, 2006 9:01 pm    Post subject: How do I rollback to 2.70? Reply with quote
The title asks the question!
Thanks in advance for your help.
Alang
timber
PostPosted: Sat May 06, 2006 9:17 pm    Post subject: Re: How do I rollback to 2.70? Reply with quote
Alang wrote:
Alang
unzip file connect your I3 using usb cable back up any favorites (They will be lost otherwise) then install the following.
http://makeashorterlink.com/?C1AF2211D
Will host for 48 hours
Alang
PostPosted: Sun May 07, 2006 1:10 pm    Post subject: Reply with quote
Hi timber
Thanks for help, its all sorted now. :D
I had downloaded 2.70 into the wrong folder, Confused thats why I could not get it to work. Embarassed
Alang
Coaster2
PostPosted: Tue May 16, 2006 8:57 pm    Post subject: Reply with quote
Sorry to be a pain but I'm new to this. I am on V3 and it is rubbish. I've downloaded v2.7 which was fine. How do I go about getting 2.7 back into the i3 please?
timber
PostPosted: Tue May 16, 2006 9:21 pm    Post subject: Reply with quote
Double click on the 2.70 zip file then select a folder to unzip to suggest c:\temp.
Have you installed the I3 usb driver if not obtain from here and install
http://www.garmin.com/support/download_details.jsp?id=591
Now connect the I3 to your PC using the usb cable the i3 will power on its self.
Go to the folder you unzipped 2.70 to and double click on the loader icon select usb option and then select next.
Accept the warning that you are going to put a earlier release of software on and proceed on let the erase and load take place untill the message comes up that it has finished.
Go through the settings and ensure they are to your satisfaction (they have all been set to default)
And that should be you back on 2.70
Coaster2
PostPosted: Tue May 16, 2006 9:28 pm    Post subject: Reply with quote
Many thanks Timber; job done.
Coaster2
PostPosted: Tue May 16, 2006 9:57 pm    Post subject: Reply with quote
One thing I found was that it erased all my favourites. Is there any way that these can be backed up?
timber
PostPosted: Tue May 16, 2006 11:04 pm    Post subject: Reply with quote
As for backing up your favorites download from here :
http://www.easygps.com/download.asp
When you have downloaded and installed select preferences and then add gps from dropdown menu select garmin and finally I3.
Receive will read from the I3 and of course send does what it says.
When you read you then can save to your PC so that next time you can load this file and send direct to the I3
Coaster2
PostPosted: Wed May 17, 2006 12:11 am    Post subject: Reply with quote
Many thanks Timber, works a treat.
22.051 (01 May 24)
