Pocket GPS World :: View topic - Garmin XL12 to T3 or iPAQ2210
JohnF
PostPosted: Sun Nov 23, 2003 9:11 pm    Post subject: Garmin XL12 to T3 or iPAQ2210 Reply with quote
Hi, I have a Garmin 12XL which I want to connect to a Palm T3 or iPAQ
H2210. The Garmin has a serial output whereas the PDA's have the Palm
Universal Bus and the USB. Are there any adapters available. I have found
some Serial/USB intended for modems etc to a PC. These have drivers for
Windows. Presumable they would not work without drivers for the PDA.
Regards JohnF
PostPosted: Mon Nov 24, 2003 3:12 am    Post subject: Reply with quote
The iPAQ 2210 has a "normal" serial port , using the same connector as the 3xxx and 5xxx series. "Normal" because in reality it is an emulated serial port off the USB bus. So it has the converter already built in that you are mentioning.
JohnF
PostPosted: Mon Nov 24, 2003 8:37 am    Post subject: Reply with quote
Lutz, Thanks for that info. Do you know how the conection would be made physically as the Garmin cable has a serial plug & PDA will have a USB type. Also would any drivers be required.
BTW I have found a Comact Flash - RS232 Card at www.dpi.com.
Regards John.
22.052 (08 May 24)
