Pocket GPS World :: View topic - Bluetooth battery life and car connection question.........
ColinR
PostPosted: Fri Nov 07, 2003 10:20 am    Post subject: Bluetooth battery life and car connection question......... Reply with quote
I read some posts in this forum that seem to indicate that BT recievers have a limited battery charge cycle lifetime. Does this mean that when the battery will no longer take a charge the BT receiever will not work, even if it is connected to the 12V car supply?? Rolling Eyes
Could you connect the BT unit to a constant 12V supply therefor never using the BT battery ( i dont intend to ever take the BT reciever out of the car) or would constant connection drain the car's battery over time.
PostPosted: Fri Nov 07, 2003 12:17 pm    Post subject: Reply with quote
The battery life cycle on most are around 400 charges. This is the same as a mobile phone, after which time battery performance will be impacted, e.g. you won't get 6 hours out of the batter, perhaps 3 or 2 hours, depending on battery condition. You will still be able to plug it in to the mains/accessory socket.
22.053 (15 May 24)
