Pocket GPS World :: View topic - PDA with builtin GPS as Laptop GPS
lohtse
PostPosted: Thu Feb 02, 2006 7:19 pm    Post subject: PDA with builtin GPS as Laptop GPS Reply with quote
Hi All
Sorry if this has already been answered. But Is it possible to use a PDA with built in gps as a PC/Laptop GPS if so how would I do this such as software and port settings etc?
Regards
Andrew
lbendlin
PostPosted: Fri Feb 03, 2006 4:18 am    Post subject: Reply with quote
yes, head over to our partner site
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=46333
Lutz
TomTom/TeleAtlas NAVTEQ
lohtse
PostPosted: Sun Feb 05, 2006 10:43 am    Post subject: Reply with quote
Thank you for your reply but could not find a mention of using a internal/builtin pda gps on a laptop could you clarify please...
thank you for your help
regards
Andrew
lohtse
PostPosted: Sun Feb 05, 2006 10:50 am    Post subject: Reply with quote
I should have actauly said that I found what you had said only useful to a bluetooth enabled device and I then realised I had not stated that my device had no bluetooth.... Sorry folks.
So will ask again is it possible to use a pda with a builtin gps as a laptop gps via a serial/usb cradle or cable (medion pna100 has serial usb link).
regards
Andrew
Aitch2
PostPosted: Sun Feb 05, 2006 11:22 am    Post subject: Reply with quote
The Franson GpsGate software might be part of the answer?
http://www.franson.com/gpsgate/
Aitch
Find Somewhere Else 090407: www.marillion.com
lohtse
PostPosted: Sun Feb 05, 2006 10:32 pm    Post subject: Reply with quote
Thank you for your reply.I use gpsgate for port splitting etc on the pda and works great but how would In use it for pda gps to laptop gps??
regards
Andrew
Aitch2
PostPosted: Sun Feb 05, 2006 10:42 pm    Post subject: Reply with quote
I guess it was the mention of wanting to transfer GPS data over a USB cable? I need the GpsGate software to do this with my i3...(which I use to drive MS Autoroute sometimes...)
Aitch
lohtse
PostPosted: Mon Feb 06, 2006 2:13 pm    Post subject: Reply with quote
How did you do this "transfer GPS data over a USB cable? I need the GpsGate software to do this with my i3" ?
regrards
Andrew
Pc-Mobile
PostPosted: Tue Feb 07, 2006 11:49 am    Post subject: Reply with quote
You cannot do that over USB.
GPS (NMEA) data, with small percentage of exceptions, can only be transferred via serial.
As for the original post, intending to output GPS data from PPC with built in GPS to a PC, you will need first, as another member already pointed out, a serial splitter application like GPSgate on the PPC, and you have to export it through the serial port (BT is a serial port) of the PPC to the serial port of PC like this:
PPC>PPC serial cable>null modem adapter>PC serial cable>PC.
WM5 PPC is supposed to have virtual serial ports builts in so serial splitter application might not be needed but I have yet to test if that is the case.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.044 (24 Apr 24)
