Pocket GPS World :: View topic - Changed format of the PGPSW camera database
dougconran
PostPosted: Tue Jan 03, 2006 8:38 pm    Post subject: Changed format of the PGPSW camera database Reply with quote
PGPSW have changed the structure of the camera database for the i3, they have split out Gatsos and Mobiles into separate files for each speed with an associated icon showing the relevant speed.
Personally I think that is a retrograde step because I can't see the speed on the icon but I guess others will find it a benefit.
However - MaFt, can you remind me why it was that you re-named the camera files to zSpeed ... and is it something we should re-instate for the new files? (maybe it won't matter now Sad )
andspenka
PostPosted: Sat Jan 07, 2006 12:44 am    Post subject: Reply with quote
As far as I can remember it was just to put them to the bottom of the list, so when you're searching your custom points you don't get a load of cameras in the middle of your other POI's.
Andspenka
TomTom One V2
PaulB2005
PostPosted: Sat Jan 07, 2006 2:40 am    Post subject: Reply with quote
You an always replace the icons with the icons you like from another set. i.e. take the zSpeed Cam - UK.bmp and rename it to pocketgps_uk_gatso_20.bmp, pocketgps_uk_gatso_30.bmp, pocketgps_uk_gatso_40.bmp etc
PostPosted: Mon Jan 09, 2006 1:26 pm    Post subject: Reply with quote
that's correct.
also, i use the ones from the main download cos i don't like having individual files for each speed...
dougconran
PostPosted: Tue Jan 10, 2006 9:22 pm    Post subject: Reply with quote
Thanks for the replies everyone.
timbouk
PostPosted: Sun Jan 15, 2006 9:27 pm    Post subject: Re: Gatso and Truvelo Reply with quote
StellaMaris wrote:
On the files there are none for the Truvelo? Are these actually in the Gatso files, but just named Gatso for the Garmin GPS's?
I think they must be
Can I suggest that the truvelo are kept seperate. These work by clocking you between the cameras, ideally need to know the distance between a pair and adjust the warning distance to suit. Does that make sense?
PostPosted: Sun Jan 15, 2006 9:37 pm    Post subject: Re: Gatso and Truvelo Reply with quote
Truvelos do not measure an average speed. They are a camera that takes a photo of the front of the car as you cross strips laid in the road.
Specs are the cameras that measure the speed between 2 cameras.
timbouk
PostPosted: Sun Jan 15, 2006 9:59 pm    Post subject: Reply with quote
oops, i was really sure that the truvelos did that. Sorry ;)
OK then, are specs kept differently?
