Pocket GPS World :: View topic - Fail To Open Database = 2
pyrator
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Fail To Open Database = 2 Reply with quote
I've been transferring routes between my Pocket PC and Fugawi UK using the Pocket PC Data Exchange. Whilst Tracks, Maps and Waypoints appear to show up as being present on the PDA, Routes do not. I have also received the message "Fail To Open Database = 2" when I do a fresh start on Fugawi on my Pocket PC. Would anyone know if the two are related and what the fix is?
Regards
Keith
colt5068
Keith,
I've got the same problem just sent the following to Fugawi Support.
Last week I purchased FUGAWI UK from Global Positioning systems here in the UK. I have sent registration to you but probably has not yet arrived. If required I will email CD key as proof.
I loaded software to laptop running Win 2000 SP 4 & then downloaded & installed the upgrade from your web site & all works well - very impressed !!
I then installed on my IPAQ 2210 running pocket pc 2003, along with the world map & this too is OK. I then selected a map section & exported to Ipaq but when selected get the error message " Fail to Open Database = 2". But I can see the map in the background with the error message not being able to clear.
I have tried 3 different map sections ( only small areas ) loaded to PDA memory , CF card & SD Card with same result.
Am I doing something wrong or is there something else I need to do ??
Colin
pyrator
PostPosted: Fri Sep 19, 2003 3:53 pm    Post subject: Reply with quote
After trying to find a simpler solution to this problem - which I think was caused by a lock on the database used by Fugawi, the only way I found of stopping this message was to uninstall FUGAWI, and reinstall and then export the routes again
Rat
PostPosted: Sun Mar 28, 2004 11:03 pm    Post subject: failed to open database=2 Reply with quote
I have had this same error " failed to open database=2" I think I have cured it by deleteing a file in the programe files/fugawi folder I think it was called somthing like dbsouce it was the only file in the folder apart from fugawi.exe.
I had the problem, that after starting Fugawi you could not close it because of the message failed to open database=2. so I had to end task or reset.
It is early days but all seems well again.
2210 futura clipon BT
Fugawi / TT2
with Tomtom ~gpg removed
so all have a chance of useing the BT GPS
BBB
PostPosted: Mon Mar 29, 2004 11:01 pm    Post subject: Reply with quote
Forgive me - I may be hoplesslt off-track here but I was wondering which version of Fugawi you are using?
There may be some general things about different versions. Have you imported all the maps? Elevation data too? Maybe even come across a reference to an unknown folder supposed to be on the C: drive?
BBB
22.051 (01 May 24)
