Pocket GPS World :: View topic - TT5 BT GPS in Ford Focus
terryd
PostPosted: Sun Dec 04, 2005 8:50 pm    Post subject: TT5 BT GPS in Ford Focus Reply with quote
I've bought my son TT5 with BT GPS for Xmas but suspect he will have a problem operating in his 'W' reg Ford Focus Ghia with heated front screen.
Will he need a special antenna or not? Any thoughts welcomed.
Terry:
IPhone SE, TomTom GO, Memory Map (UK & France), Linesman
PostPosted: Sun Dec 04, 2005 9:15 pm    Post subject: Reply with quote
Terry, I use far less capable GPS units in the Focus hire cars (with heated screen) that I have on a regular basis (note prior to the decent Holux 236 I know have, I was using a Fuzion unit and that is what I am refering to for comparison purposes - if the Fusion works then TT wil be fine) , I don't think there will be any problem at all - its a decent GPS unit so you should be more than OK - Mike
alan_m
PostPosted: Sun Dec 04, 2005 11:18 pm    Post subject: Re: TT5 BT GPS in Ford Focus Reply with quote
The heated screen may attenuate the signal slightly but it should be OK.
Furthermore, there is an area at the bottom corner of the screen that is free of the heating elements. Place the BT receiver in the corner of the screen - my wired GPS receiver works perfectly in this location on my Focus.
tomo1340
PostPosted: Sun Dec 04, 2005 11:27 pm    Post subject: Reply with quote
I thought it was the heat reflective screens that were the problem?
o2 XDA Stellar
TTN6
MOWE
Fat_Jez
PostPosted: Sun Dec 04, 2005 11:53 pm    Post subject: Reply with quote
I use Tomtom 5 with a Palm PDA and a Globalsat BT-338 in my Ford Focus LX which has a heated front screen. The TTFF is quite impressive, it must be said and the unit maintains a good lock. If I recall correctly, the GPS unit with TT5 uses the same chipset, so should perform equally well.
Cheers,
Stephen
DigiBloke
PostPosted: Mon Dec 05, 2005 6:08 am    Post subject: Reply with quote
I had a problem with a reflective front screen so I put the BT-GPS in the back window, works great...
terryd
PostPosted: Mon Dec 05, 2005 3:24 pm    Post subject: Thanks for reassurance Reply with quote
Thanks to all you guys who commented. My son should now have a Happy Xmas!!
Terry:
MikePen
PostPosted: Tue Jan 10, 2006 8:26 pm    Post subject: TomTom BT fine in Alhambra / Galaxy Reply with quote
I've been using the TomTom BT receiver under the front heated screen on my Seat Alhambra (same as the Ford Galaxy) and its absolutely fine.
tomo1340
PostPosted: Wed Jan 11, 2006 6:40 pm    Post subject: Reply with quote
I am sure its heat reflective windscreens which cause a problem, not heated windscreens. ie the signal will be reflected off the windscreen along with the nasty heat.
o2 XDA Stellar
TTN6
MOWE
22.052 (08 May 24)
