Pocket GPS World :: View topic - Problems with POI's on Iberia Plus maps
floody
PostPosted: Wed Nov 16, 2005 11:09 am    Post subject: Problems with POI's on Iberia Plus maps Reply with quote
I am going to Spain tomorrow so I loaded the Iberia Plus maps onto my SD card & thought I'd plan a few routes. When I browse the map I can see all of the POI's (in particular golf courses). My problem is that when I try & use A-B planning or FIND using a POI I get the message "No Valid GPS Signal" & then when I choose a POI category it says "No POI found".
I have tried this when I have a GPS signal but still no luck. :x
I have had no problems using the GB Plus maps.
I installed the maps via active synce using the install program, do I need to copy/install anything else??
What I have done as a work around solution is browse the map to find my POI & then save it as a favourite, this then works.
Any ideas???
Thanks.
floody
PostPosted: Wed Nov 16, 2005 2:47 pm    Post subject: Reply with quote
Come on guys, any ideas??? I'm getting desperate.
Privateer
PostPosted: Wed Nov 16, 2005 3:35 pm    Post subject: Reply with quote
Hi floody,
Are you using the standard built-in POIs that come with TomTom or some third party POIs?
Are you using a legitimate or pirate copy of TomTom Navigator 5?
What version of TomTom Navigator 5 are you using (5.00 or 5.10)?
Can you browse the Iberia Plus maps?
Robert.
Garmin Camper 770 LMT-D
floody
PostPosted: Wed Nov 16, 2005 4:20 pm    Post subject: Reply with quote
Privateer,
I'm using built in POI's ,legit copy, V5.0 & yes I can browse the map, I can even see the POI's when I browse which is why it's getting me stumped.
Privateer
PostPosted: Wed Nov 16, 2005 6:46 pm    Post subject: Reply with quote
Hi floody,
I’m not using the Iberian Plus maps (haven’t loaded them), however I’m using GB Plus on my iPAQ 2210 and I’ve connected to my BT GPS Receiver (GlobalSat BT-338). I’m in a shielded building so even my trusty SiRF III receiver can’t get a satellite lock on!
Right, using Advanced planning, if I select Point of interest, I also get the “No valid GPS signal” message flash up. However the system allows me to select a POI for both Departure and Destination locations. I can then run the demo using those two locations.
You may want to install TomTom Navigator 5.10, but before you do ensure that you have a viable backup, preferably by Sprite backup.
Robert.
