Pocket GPS World :: View topic - TT5 on an XDA, No GPS signal
MMCrew
PostPosted: Wed Oct 26, 2005 3:30 pm    Post subject: TT5 on an XDA, No GPS signal Reply with quote
Hi people, iv finally got TT5 on my xda 1,
i connect the GPS reeiver into the xda and it just keeps saying no GPS Signal, i select other Cable NMEA GPs and go through all the Baud Rates
and then it gives me the option of
which port,
either com9
Seriel calbe on Com1
Seriel on USB
Seriel on COM2
now im assuming its gonna be com1 or 2 considering im using a wired GPS reveiver,
here is the spec of the GPS reciever,
Advanced IC technology allows total receiver cost saving
Allows the receiver to track up to 12 channel satellites
Fast TTFF for cold start, warm start and hot start
High performance firmware drives an excellent positioning speed
Serial communication channel with user selectable baud rates allows maximum interface capability and flexibility
Supports backup power to sustain internal clock
Suitable for notebook, PC, PDA and others
Optional USB cable, PDA connector
Accuracy: Position: 5m without SA Velocity: 0.1m/second without SA Time: +1u seccond
Acquisition: Cold start: 50 seconds (average)
Warm start: 35 seconds (average)
Hot start: 2 seconds (minimum)
Sensitivity: Acquisition: -139dBm Tracking: -152dBm Dynamics: Altitude: maximum 18,000m Velocity: maximum 500m/second
Acceleration: maximum +/-4g Navigation update rate: once per second Serial I/O: series RS-232 signal 4.8K (optional 9.6K)
NMEA 0183: GGA, GSV, GSA, RMC, (optional VTG, GLL) Coordinate datum: WGS 8
4 Power supply: 5 to 9VDC Power consumption: typical (tracking): 120mW
Sleep mode power saving: yes (automatic) RTC support: yes Waterproof: yes
System performance: tracks up to 12 satellites L1, C/A code
Operating temperature: -40 to 85 degrees Celsius Storage temperature: -55 to 100 degrees Celsius Humidity: 5 to 95 percen
what can it be, it still wont work HELP
alix776
PostPosted: Wed Oct 26, 2005 3:41 pm    Post subject: Reply with quote
use com 1 at a baud rate of 4800 and in connections go to beam and uncheck the box
device Lumia 950 xl
