Pocket GPS World :: View topic - No valid Gps signal!
mynottb
PostPosted: Fri Oct 21, 2005 9:12 pm    Post subject: No valid Gps signal! Reply with quote
Followed TomTom instructions and still no joy.
Its bonded and finds satalites with blue/yellow wheel spinning with time but
says No valid Gps signal! even when left for hours still no good?.
PLEASE help
COMPAQ 3970
BT GPS BLUETOOTH
alix776
PostPosted: Fri Oct 21, 2005 9:17 pm    Post subject: Reply with quote
where have you left the gps does it have a clear veiw of the sky it might be an idea to drain the gps battery then recharge it and try again
device Lumia 950 xl
mynottb
PostPosted: Fri Oct 21, 2005 10:16 pm    Post subject: No valid Gps signal! Reply with quote
The receiver is in on the window ledge.
Why does it see the satalites but wont work?
PostPosted: Fri Oct 21, 2005 11:42 pm    Post subject: Reply with quote
Exactly which GPS unit is it - if it is in sirf mode TT5 won't recognise it - (TT3 did) you need to det it to NMEA - just a thought - Mike
Robin2
PostPosted: Sat Oct 22, 2005 10:13 pm    Post subject: Reply with quote
If it hasn't been used for some time, you need to leave it on for up to 15 minutes before it will get a fix, and it almost certainly won't lock on if you are moving.
For example, I have 2 receivers, and this afternoon switched on one which I haven't used for about 4 weeks. I didn't have time to wait around, so started driving straight away and it hadn't managed to fix after an hour. When I got back home I parked the car in the drive and left it switched on. Five minutes later it had a fix! When I used the car about 3 hours later, the fix was instantaneous
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
22.053 (15 May 24)
