Pocket GPS World :: View topic - Low Bridges
Low Bridges
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge
SharpEye
PostPosted: Wed Aug 10, 2005 2:20 pm    Post subject: Low Bridges Reply with quote
I thought I would commend Robin on his low bridges database.
It wouldn't initially work on my 2210 with TTN3 but once I sussed out that the lat and long was reversed and corrected the file it now works a treat. Clap
Keep up the good work
SharpEye
mark5290
PostPosted: Wed Sep 21, 2005 2:07 pm    Post subject: Reply with quote
Yep, a big thankyou to Robin, i would like to get hold of the individual bridge height icons like this.
Pocketgps
PostPosted: Wed Sep 21, 2005 8:20 pm    Post subject: Reply with quote
Try my POI files page, click link at bottom of this post.
mark5290
PostPosted: Thu Sep 22, 2005 1:28 am    Post subject: Reply with quote
Wow, a big thank you to you aswell, just what i was looking for, i was expecting just to find the poi icon bmp's, which would mean i would have to match them up to Robin's ov2 file, but no you have done that aswell, excellent.
[cheeky mode]i wonder if anyone out there has done a weight limit ov2 & bmp yet[/cheeky mode]
Laughing
Mavrik
PostPosted: Mon Oct 17, 2005 9:18 am    Post subject: Reply with quote
How can I get hold of the low bridge POI's ?
HP hx4700, Tom Tom bluetooth, Seidio mount
Pocketgps
PostPosted: Mon Oct 17, 2005 3:51 pm    Post subject: Reply with quote
Have a look on the POI Files page on my web site, just click the link at the bottom of this post.
Mavrik
PostPosted: Mon Oct 17, 2005 6:00 pm    Post subject: Reply with quote
Thanks for that
got it now
Laughing Laughing
Flat_Battery
PostPosted: Sat Oct 22, 2005 8:50 am    Post subject: Reply with quote
Just downloaded and installed the database. Thanks a lot. :D :D
Jim
trueno86
PostPosted: Mon Oct 24, 2005 1:14 pm    Post subject: Reply with quote
can this be used with a garmin i3 ?
thanks
biker-pete
PostPosted: Sat Feb 11, 2006 5:55 pm    Post subject: Reply with quote
Hi wondered if anyone can help i have a navman 510 sat nav and need bridge heights for the truck i am driving can anyone help thanks
Pocketgps
PostPosted: Sat Feb 11, 2006 6:29 pm    Post subject: Reply with quote
thanks
My files can be used on the i3, but after downloading the file you would need to un-zip as normal, then when you know which files you want to use (either the separate heights or the single file) you would need to change the file format type as they are either .ov2 or .asc in the included zip.
The file type the Garmin uses is .csv, so you would need to choose and change the .asc to .csv file format.
If you just right click each file and then change the file name
eg
AMN_LOW_BRIDGE_ALL.asc
to
AMN_LOW_BRIDGE_ALL.csv
it will work as the file structure inside the file is the same, it's just the file format name that is different. I have just this minute tried it with that file myself on my i3, but having not driven around to try it I am not sure what warning bong you get Exclamation
Don't forget the silly rule that the Garmin PoiLoader removes ALL existing files when loading new ones, so if you had the Safety Camera poi's before you will need to add the low bridge poi(s) to that folder when you load them or you will end up with just the low bridge poi(s).
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge All times are GMT + 1 Hour
23.053 (21 May 25)
