gbexor Occasional Visitor
Posted: Sat Sep 24, 2005 12:52 am Post subject: Connecting Garmin GPSmap 60cs with TTN5 |
I apolgise in advance if there is already a thread on this but I have tried to check the threads in TT & garmin sections to no avail.
Basically I have TTN5 on my SPV M2000 which I normally use with my Emtac BTGPS. It works fine on this setup. However my husband has since bought himself a Garmin GPSmap 60cs & it seem pointless to carry 2 gps around (& HE WONT LEAVE HIS BEHIND) so I got myself the necessary connection cables (PCmobile ones) but no matter what I tried I cant seem to get any gps connection to the pda.
I have set up the Garmin for NMEA In/NMEA Out & the baud rate automatically sets at 4800. The settings in TTN5 used is the OTHER CABLE NMEA GPS, tried it on all the different baud rates & the only slight hint of it trying to communicate is when the baud rate is set to the highest i.e. 115200 & I chose COM1 - the little circle on the top right hand corner moves as if its trying to connect. But that it.
Can anyone help? Is there anyway to find out if its the cable or just me??? I hope someone out there can help.
Many thanks in advance. _________________ SPVM2000,TTN5,EmtacBTGPS,Garmin GPSMap60CS,brodit mount |
lbendlin Pocket GPS Staff
Posted: Sun Sep 25, 2005 2:21 am Post subject: |
COM1 at 4800 would actually be correct. But are you sure your SPV actually has a serial port? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Sep 25, 2005 12:44 pm Post subject: |
Eh - what is serial port? I am a womon for goodness sake! How do I check? _________________ SPVM2000,TTN5,EmtacBTGPS,Garmin GPSMap60CS,brodit mount |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Sun Sep 25, 2005 6:21 pm Post subject: |
I'm talking from my failing memory here ,but I think I have read some where about un ticking the "Receive incoming beams" box.
Dave |
Posted: Sun Sep 25, 2005 9:49 pm Post subject: |
Thanks for the suggestion, Dave but that box is unticked. _________________ SPVM2000,TTN5,EmtacBTGPS,Garmin GPSMap60CS,brodit mount |
