Pocket GPS World :: View topic - ORIGIN B2 PC CONNECTION
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems
RobM
PostPosted: Mon Sep 05, 2005 11:22 pm    Post subject: ORIGIN B2 PC CONNECTION Reply with quote
Can any of you help with a B2 GPS receiver connection problem.
I have just purchased a B2 and accessory cradle that can output an NMEA stream with the intention of connecting it to my laptop to drive navigation software such as Infomap.
To get it working I believe I will need to cut the end of the supplied RJ11 connector and solder an db9 serial adaptor to one end.
Does anyone know the correct pin assignments and wire colour coding to make this work???
Unless my eyes have gone bad tonight I can only see three wires in the rj11 coming from the cradle but four in the patch lead also supplied.
I have phoned origin who advised to connect yellow wire to pin 2 and green to pin 5 of a db 9 pin serial connector, which I have done. After downloading a number of trial sat nav programs as a test prior to making a purchase, only to find that either the data stream is not recognised as nmea 2.0 compliant or causes a coms buffer overflow.
Any help is appreciated.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems All times are GMT + 1 Hour
22.044 (24 Apr 24)
