madasaman Occasional Visitor
Posted: Sun Aug 14, 2005 1:50 am Post subject: voice warnings for safety cameras |
Where do i put the voice warnings in tom tom 5 so that i can access them in the program. At the moment i can only access the sounds in built into tomtom. I've put some voice files into the relevant map folder but they dont show up as they did with version 3.
Madasaman
HP Ipaq 2215
BT308
512 SDcard |
lbendlin Pocket GPS Staff
Posted: Sun Aug 14, 2005 5:14 am Post subject: |
the data.chk file is in the application folder, not in the map folder. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Aug 14, 2005 8:33 am Post subject: |
lbendlin wrote: | the data.chk file is in the application folder, not in the map folder. |
I'm quite useless at this, i found the said file in tom tom but cant seem to put in any wav files, can you give a moron some instructions.
Thanx
Graham |
Oldboy Pocket GPS Moderator
Posted: Sun Aug 14, 2005 8:59 am Post subject: |
You don't use .wav files at all.
You use the new data.chk file which you can get from here.
Just make sure you choose the one that matches your system. _________________ Richard
Posted: Sun Aug 14, 2005 9:12 pm Post subject: |
Oldboy wrote: | You don't use .wav files at all.
Just make sure you choose the one that matches your system. |
Have read through the instructions and checked the application and build it is app 5.000 (4890) do i download the 4890 file and follow the install directions for the tom tom go. I have a data.chk file in program files/ navigator with no number and one in tomtom called data05.chk which do i replace? |
Posted: Sun Aug 14, 2005 10:09 pm Post subject: |
madasaman wrote: | Have read through the instructions and checked the application and build it is app 5.000 (4890) do i download the 4890 file and follow the install directions for the tom tom go. I have a data.chk file in program files/ navigator with no number and one in tomtom called data05.chk which do i replace? |
It's the one in Program Files\Navigator that you have to replace. Data05.chk is Janes Navigation Voice file. _________________ Richard
Posted: Mon Aug 15, 2005 1:22 am Post subject: |
Oldboy wrote: | madasaman wrote: | Have read through the instructions and checked the application and build it is app 5.000 (4890) do i download the 4890 file and follow the install directions for the tom tom go. I have a data.chk file in program files/ navigator with no number and one in tomtom called data05.chk which do i replace? |
It's the one in Program Files\Navigator that you have to replace. Data05.chk is Janes Navigation Voice file. |
Ok I now understand what file needs replacing, so i download the 4890 version, rename it data.chk and install it into program files/navigator copying original to pc first and renaming it as old. Do i need to delete it from navigator or will it be overwritten? Sorry to be such a thicko |
Posted: Mon Aug 15, 2005 7:08 am Post subject: |
Doesn't really matter. I personally delete first. _________________ Richard
