Pocket GPS World :: View topic - TT5 BT338 - Location Delay
mikeprytherch
PostPosted: Thu Aug 04, 2005 4:57 pm    Post subject: TT5 BT338 - Location Delay Reply with quote
I have just purchased a BT-338 and I am running it with TT5 on an Ipaq 5450. Since using the new GPS (instead of the original TT Wired GPS) I have noticed that the location on the map is around 30 yards behind where I am, in other words I have gone past the junction before TT realises and therefore the instructions are late... any ideas ?
cootuk
PostPosted: Thu Aug 04, 2005 7:01 pm    Post subject: Reply with quote
walking or driving?
driving normally or slowly?
There is a mode whereby the gps only updates every few metres if you are going slowly due to the inaccuracies of older recievers - the BT338 should be shipped with this mode off as it has greater sensitivity.
mikeprytherch
PostPosted: Thu Aug 04, 2005 7:02 pm    Post subject: Reply with quote
While driving... not matter what speeds, in fact it seems worse when going quickly, its like it running super slow and can't keep up !
ginosergio
PostPosted: Wed Aug 31, 2005 11:56 am    Post subject: Reply with quote
Mike, if this happens constantly you may have some serious problem, but if this happens "sometimes", I'm quite sure that this is the "parity error problem" that give position errors in BT-338 with 3.0.2 firmware.
I own a BT-338 and I also had problems like this, one/two times everyday, before upgrading to 3.1.1 firmware.
Regards.
mikeprytherch
PostPosted: Wed Aug 31, 2005 12:01 pm    Post subject: Reply with quote
Thanks thats great, can I please ask, how do you go about upgrading the firmware ?
ginosergio
PostPosted: Wed Aug 31, 2005 12:38 pm    Post subject: Reply with quote
You can send your BT-338 for upgrade, to Globalsat USA, read here:
http://www.usglobalsat.com/item.asp?itemid=82
or you can do it by yourself...
read my message in topic:
"BT 338 firmware update now taking place!"
Regards
mixer25
PostPosted: Mon Sep 05, 2005 1:12 am    Post subject: Reply with quote
I got same issue with mine, it takes sometimes 5 minutes to lock on and sometimes doesn't at all and then I have to soft reset PDA and switch off GPS and back on, then it works.
I will update, but it sucks paying to update something that went out wrong.
mixer25
PostPosted: Mon Sep 05, 2005 10:17 pm    Post subject: What the Firmware Does Reply with quote
THIS FIRMWARE UPGRADE WILL:
* Upgrade your receiver to allow the SiRF III chipset to be WAAS capable and activated via the “SiRF DEMO” utility software. *
* Improves acquisition and also improves bit sync capability and recovery mode. (This error can cause fix problems from reacquisition after a blockage from receiving data also know as the ‘jet-lag” symptom).
* Improves cold start frequency search range problem, where frequency was not searched properly after 30 seconds.
* Improves potential cold start visible list problem, which could affect performance if all satellites are below 32 db-Hz
* Corrects Message “41” datum field.
* Corrects date stamp not updating.
* Limits the 50 BPS thresholds to 27 to avoid undetected parity errors, which can give position errors.
THIS FIRMWARE UPGRADE WILL NOT:
Change the current function of the “Auto Shut-Off” to activate after 10 min if no Bluetooth connection is present to conserve battery life. This feature is NOT correctable with any firmware upgrades, it is a hardware design with plans to modify the function as a running change on production units by the end of the year.
22.051 (01 May 24)
