Pocket GPS World :: View topic - USB Help
USB Help
Trix
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: USB Help Reply with quote
My Packard Bell XP laptop can't see the USB cable and can't find the driver
GPS is GPSmart
HELP
Trix
Got it to work but guess that it is about 10 metres out.
Is this normal? Using a PC Map travelling along a road by the sea shows up that I am in the sea!
Pc-Mobile
It is more than likely that it is the map software that is at fault.
Pc-Mobile
http://pc-mobile.net/gps.htm
Trix, firstly check you're using WGS84 as the datum, and secondly if you are using a scanned map, then you will need to calibrate it with more points. If you're using a commercial map product like Memory-Map, then you're probably using the wrong map datum.
Trix
Thanks for these.
Software is Navigator GB and GPS Setting is ORD.Survey GB withBritish Grid
Ordnance Survey GB with British Grid isn't used much, most receivers tend to prefer WGS84, so I would try setting the Fortuna to this as this might make a difference. Certainly all the Garmin's and Magellan's I set to WGS84 and these work well.
I believe there were issues with not being able to change the Fortuna's Datum, until the firmware upgrade, so you might have to download and flash it to do that. If you do, the firmware update is on our downloads page.
Trix
Thanks for this.
My Receiver supports WGS84, and is spot on.
The firmare number on it is 1.24
Should I still try to upgrade it?
My unit is NOT Bluetooth
John
22.051 (01 May 24)
