Pocket GPS World :: View topic - Fix for satellites not showing on TTN5
stevei
PostPosted: Mon Jul 04, 2005 8:44 pm    Post subject: Fix for satellites not showing on TTN5 Reply with quote
I have just had a play with a program called "Crux II GPS View" by Emtac. This can be found at http://www.gpsoz.com.au/bluetooth_crux_ce.htm.
I set up the Com Port and Baud rate as usual, then in the Protocol Tab I clicked on the "Set NMEA Update Rate", then on the SBAS Tab i changed the SBAS Channel setting to auto.
Lo and behold I now have satellites showing in the status bar and GPS Status.
It works for my Leadtek 9531, I see no reason why it shouldn't work for all.
I hope that this is of some use to those with this problem.
Steve I
jamiepyoung
PostPosted: Tue Jul 05, 2005 12:05 pm    Post subject: Reply with quote
can you explain this a bit more for me please - sorry!
stevei
PostPosted: Tue Jul 05, 2005 5:53 pm    Post subject: Reply with quote
Jamie
I had a problem that, although everything worked OK except the satellite bar on the status bar remained blank, and the GPS setup in the setup menu showed a position but no bars on the display.
Do you have this problem?
Steve I
jamiepyoung
PostPosted: Tue Jul 05, 2005 8:27 pm    Post subject: Reply with quote
No!
I thought this might help with the apparent slow refresh rate I get on the map.
Thanks though.
