Pocket GPS World :: View topic - Spoken warnings for POI alerts!
ned1
PostPosted: Sat Jul 02, 2005 12:12 pm    Post subject: Spoken warnings for POI alerts! Reply with quote
Hi all (again)
Just trying to install the Spoken warnings for POI alerts into my ttg 300
have tried to follow the instructions on this site but am not sure because
mine is not the same (I have a 5.2) as the one on the screen, can anyone give me a idots guide please.
ned Question
ps can I still use the old ones for other poi warnings
PostPosted: Sat Jul 02, 2005 12:55 pm    Post subject: Reply with quote
http://pocketgpsworld.com/tomtom-poi-alerts.php
use the file for build 5244
ned1
PostPosted: Sat Jul 02, 2005 1:37 pm    Post subject: Reply with quote
Hi I have got that file but am concerned that I will mess it up because I cannot find :-
data04.chk
data05.chk
etc,etc
that's why I would like a idots guide !!
discoverytdi
PostPosted: Sat Jul 02, 2005 2:50 pm    Post subject: Reply with quote
I've just installed the Spoken warnings for POI alerts into my ttg 300, however it seems to over write the original warning sounds, as I would like to keep some of them for other poi's. Is there a way of choseing which spoken warning are copied to the sd card as the only ones I need are the gatsco speed camera speed setting
regards peter
PostPosted: Sat Jul 02, 2005 3:41 pm    Post subject: Reply with quote
regards peter
If you read this thread it might be of help. It's a long thread but you could try starting at page 22.
TT Via 135 App 12.075: Europe Map v1145
PostPosted: Sat Jul 02, 2005 3:45 pm    Post subject: Reply with quote
data04.chk
data05.chk
etc,etc
The dataxx.chk files should be in the Root of the SD card. Did you do a full backup of your SD card? If so you can copy these back to the card remembering to check that the engf.vif and engm.vif files are also there.
ned1
PostPosted: Sat Jul 02, 2005 5:03 pm    Post subject: Reply with quote
Yes I think so I copied the card by dragging the files across and storing them on my pc in another folder,
I only have one,
data.chk 1,035 KB recovered file ragments,
which I cannot open
ned
PostPosted: Sat Jul 02, 2005 7:20 pm    Post subject: Reply with quote
I only have one,
which I cannot open
ned
When you say you only have 1, do you mean on the PC or the TTG?
The data.chk file is the voice alert file. Do not delete unless replacing with different alerts sounds.
As you have the files on your PC you should be able to Copy/Paste the dataxx.chk and .vif files on to the SD card.
ned1
PostPosted: Sat Jul 02, 2005 8:50 pm    Post subject: Reply with quote
Hello Oldboy,
I backed up the card onto my pc then put a bigger card in my ttg300 and
loaded everything back onto my ttg 300, so I am running on a new bigger card with the information from my back up on my pc with no problems.
Stop it!
Sorry about this but are you saying that this is the file to be renamed/removed and replaced by the new Spoken warnings (5244) for POI alerts
PostPosted: Sat Jul 02, 2005 10:37 pm    Post subject: Reply with quote
If you want the 5244 warnings, it replaces the data.chk file. I leave my data.chk on the card and rename it data._hk before I Copy/Paste the new one in.
ned1
PostPosted: Sun Jul 03, 2005 8:31 am    Post subject: Reply with quote
Thanks oldboy, I will have a go Wink
23.052 (14 May 25)
