Makka Occasional Visitor
Posted: Fri Jun 17, 2005 11:47 am Post subject: Delete Default POIs |
I wish to delete some of the default POI categories that came installed on my TTG 300, but the "Delete POI Category" option is greyed out.
I want to make way for downloaded POIs as I only have 2Mb left on my SD.
Any Ideas? |
Darren Frequent Visitor
Posted: Fri Jun 17, 2005 12:20 pm Post subject: |
You cannot edit or delete the default POI sets provided. _________________ Darren Griffin |
Eldar Pocket GPS Moderator
Posted: Fri Jun 17, 2005 1:48 pm Post subject: |
Darren wrote: | You cannot edit or delete the default POI sets provided. |
You can delete ALL of the default POIs, but not the single sets. |
rkm_hm Frequent Visitor
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Fri Jun 17, 2005 1:53 pm Post subject: |
ISTR seeing a recent suggestion (was it from Lutz?) that you can delete all of the built-in POIs - but not individual categories. AIUI, they are held in a file called poi.dat - which is about 1.3 MB in size. If you're feeling brave, rename it to (say) poi.da$ and check whether everything else still works. If so, and if you don't want any of the built-in POIs, you could then delete the file.
I assume that you have already deleted all the voices you don't want? If not, do that first - it's a much safer way to recover some card space! _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
Posted: Fri Jun 17, 2005 1:59 pm Post subject: |
I haven't deleted any voices, as I only have 2 as default. Other voices can be downloaded according to my TTG.
I will give renaming my poi.dat file a go and see how it goes |
Posted: Fri Jun 17, 2005 2:06 pm Post subject: |
Just tried renaming the poi.dat file (with fingers crossed and holding my breath 8O ) and it worked, so i have now deleted it and it still works fine.
Many thanks 4 your help.
I LOVE IT WHEN A PLAN COMES TOGETHER!! |
sgtbanjo Occasional Visitor
Posted: Fri Jun 17, 2005 8:50 pm Post subject: |
Does deleting these mean you can have more than 40 of your own categories or is it just to get extra space on the SD card?
Sarge |
Oldboy Pocket GPS Moderator
Posted: Fri Jun 17, 2005 9:30 pm Post subject: |
Just extra space. _________________ Richard
Posted: Fri Jun 17, 2005 10:11 pm Post subject: |
Oldboy wrote: | Just extra space. |
Are you sure? ISTR seeing claims to the contrary - but have no hard evidence. _________________ Roger
TomTom via135
Posted: Sat Jun 18, 2005 8:33 am Post subject: |
Eldar wrote: | Darren wrote: | You cannot edit or delete the default POI sets provided. |
My apologies, yes you can delete the entire POI Set but not individual POI groups. But why would you want to, the POI data is a valuable part of the device? If space is the issue get a larger memory card, with 256MB SD cards at well under £20 it is not expensive. _________________ Darren Griffin |
MartinW Occasional Visitor
Posted: Sat Jun 18, 2005 9:51 pm Post subject: |
I would like to delete it because...for example...I went on a 40 mile journey today, and the showed 2 petrol stations that weren't there and never have been in all the 30+ years i've been on those roads. |
Posted: Sat Jun 18, 2005 10:05 pm Post subject: |
MartinW wrote: | I would like to delete it because...for example...I went on a 40 mile journey today, and the showed 2 petrol stations that weren't there and never have been in all the 30+ years i've been on those roads. |
In that case, it would be nice to be able to delete indiviual POIs - but you can't do that with the built-in categories. The only option is to delete all POIs in all built-in categories - which is a bit like throwing the baby out with the bathwater! _________________ Roger
TomTom via135
Andy_P Pocket GPS Moderator
Posted: Sun Jun 19, 2005 12:45 pm Post subject: |
This sounds like a worthwhile project for one of the experts here....
Using some of the devious cleverness that has produced the custom voices for speed alerts etc. could someone come up with a way of unbundling the built-in POI file, re-editing it to add or remove items, and then re-encode it back to the original file format?
Does anyone know if this sound feasible? |
Posted: Sun Jun 19, 2005 4:24 pm Post subject: |
Andy_P2002 wrote: | This sounds like a worthwhile project for one of the experts here....
You don't want much do you. '8O'' _________________ Richard
