minesapint Occasional Visitor
Joined: 19/04/2003 22:42:21 Posts: 41 Location: United Kingdom bucks
Posted: Thu Jun 09, 2005 4:23 pm Post subject: ipaq h2210 fortuna bluetooth gps clip-on with tomtom 5 |
just installed the TomTom NAVIGATOR 5 upgrade, but i cant seem to get my fortuna bluetooth gps clip-on to connect with tomtom.
any ideas? thanks.
ipaq h2210
tomtom 5
fortuna bluetooth gps clip-on |
alix776 Pocket GPS Moderator
Posted: Thu Jun 09, 2005 5:12 pm Post subject: |
use other wired gps and then selet Bluetooth on com 8 set baud rate to 38400 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Yelesom Occasional Visitor
Posted: Fri Jun 10, 2005 9:25 pm Post subject: |
Got the same problem as minesapint but choice is 'other cable nmea gps' Is this the choice..? Also on tt3 it was on serial port 6 is 8 correct. Help |
drummer Frequent Visitor
Joined: Apr 08, 2004 Posts: 256 Location: Hampton, Middlesex, UK
Posted: Fri Jun 10, 2005 10:39 pm Post subject: |
alix776 wrote: | use other wired gps and then selet Bluetooth on com 8 set baud rate to 38400 |
Thanks for the tip. worked a treat.
This one should be made a sticky along with the 7 digit postcode fix. |
ROBBINS Regular Visitor
Joined: Dec 04, 2003 Posts: 82 Location: Worcestershire
Posted: Fri Jun 10, 2005 10:54 pm Post subject: |
Thanks for the tip. Worked with my Holux GR - 230 |
bunnyman69 Regular Visitor
Posted: Fri Jun 10, 2005 11:54 pm Post subject: |
works with a bt-77 too |
PaulBoy Occasional Visitor
Posted: Sat Jun 11, 2005 6:53 pm Post subject: |
HI - I've been trying for hours but cant get the 2210 Fortuna TT5 combo to recogniise the BT device - there's several threads on this and variations of this - can anyone help b4 I tear my hair out!
Paul :x |
adamf Lifetime Member
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Sat Jun 11, 2005 7:11 pm Post subject: tomtom5 bluetooth |
i have had the same prolems aswell when you get it working with the cable method go back to the bluetooth gps and try again this worked with mine it turns the bluetooth on automaticly which is good for power saving? just need help with the keyboard isue xda2s.. |
