cdelecole Regular Visitor
Posted: Tue Jun 07, 2005 2:12 pm Post subject: |
What I mean is that you did was taking a set of sounds that were all related to Speed Cameras.
But you have another choice which is to populate an Excel sheet with a VB macro into it, that will allow you to assign the sounds you want (The ones you recorder yourseld for example) to the Cow, Polite, Beep 1, Beep 2, etc etc present in your TT go.
That way you could have some sounds related to Speed cameras, some other being the original sounds, etc etc ,... |
jimbokb Frequent Visitor
Posted: Tue Jun 07, 2005 3:01 pm Post subject: Re POI Warnings |
Well if the warnings are just for the speed cameras what are we supposed to use for other warnings since the Data Chunk replaces all original sounds. _________________ TTG 300,External Aerial
1Gig Viking SD, 512 Viking SD(Backup)Nokia 6680 (o2), 512 MMC
Map Great Britain v 562 App v 6.150 , GPS v 1.21 Boot 4.29, OS:1221 |
Posted: Tue Jun 07, 2005 3:07 pm Post subject: |
Well, as I told you you have 2 choices :
- First is to use the set of sounds (As you did), that are all related to Speed Cameras)
- Second choice is to build your Excel sheet with VB macro that allows you to use your own recored siounds.
With option 1 you only have Speed camera related sounds.
With option 2 you have a set of sounds that you customized (Could contain a mix of Speed cameras, original sounds, Fuel station, etc etc ...).
In my case, I only Replaces "Polite 1" by a sound alerting a speed camera, and let all my other sounds the default. |
Posted: Tue Jun 07, 2005 3:19 pm Post subject: POI sounds |
Thanks cdelecole for your input but i feel mucking about with individual files may well lead to disaster, I will just have to stick with the original ones for now. I do understand what your saying but do not feel confident enough to tackle what you have suggested _________________ TTG 300,External Aerial
rayflan Frequent Visitor
Posted: Wed Jun 08, 2005 2:21 pm Post subject: RE: POI |
rayflan
Those voices at the link you provided, are you saying that I can replace just the camera warnings without disturbing all the other sound warnings. _________________ TTG 300,External Aerial
Posted: Wed Jun 08, 2005 9:04 pm Post subject: |
Checkout the readme file. Some but not all of the original sounds are there. You will have some spoken warnings for the camera pois and some of the orginal sounds for your other pois _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
blurredout Occasional Visitor
Posted: Wed Jun 08, 2005 9:50 pm Post subject: |
Ray,
Could you do your set 4 for the pocket pc version of tt5?
If so then I will forward over the data.chk file.
Blurredout |
Posted: Wed Jun 08, 2005 10:30 pm Post subject: |
Blurredout
Mail me your original data.chk and I'll give it a go, but I have no way to test it. _________________ Ray
Visit my site |
Posted: Wed Jun 08, 2005 10:36 pm Post subject: |
Thanks Ray,
I have sent a mail to you.
Blurredout |
soweezy Pocket GPS Verifier
Posted: Thu Jun 09, 2005 11:05 pm Post subject: |
Ray...
downloaded your TTN5 PPC data.chk file and installed it in the TomTom folder on the SD card but it made no difference to the warnings, I still get the bells and beeps
TTN5 on Mio168
any ideas ? _________________ SW
Garmin Zumo 390LM |
Posted: Thu Jun 09, 2005 11:20 pm Post subject: |
soweezy wrote: | Ray...
TTN5 on Mio168
any ideas ? |
Not sure....are you using v5 or v3.07?
Maybe I've uploaded the wrong file to my site. I don't have access to ttn to test but do one which was tested by someone on the forum.
Mail your original data.chk to me and I will try again. _________________ Ray
Visit my site |
Posted: Fri Jun 10, 2005 12:03 am Post subject: |
duh!...
found another instnce of data.chk in the Navigator folder, changed it and everything works...
I take it these are .ogg format sound files ?
would it be possible for you to make a new data file with my sounds ?
they can be downloaded here...
www.mumsaway.talktalk.net/pgps_sc_warnings.zip
they're already in .ogg format
thanks  _________________ SW
Garmin Zumo 390LM |
Barsnake Lifetime Member
Joined: Feb 13, 2005 Posts: 50 Location: Snottingham UK
Posted: Fri Jun 10, 2005 11:33 pm Post subject: |
You Guy's Have Been Busy With All The New Variation's
One Thing Is Can The Volume Be Increased ?
I Know This Might Be Old Ground |
