sitrap Lifetime Member
Joined: 14/05/2003 21:10:49 Posts: 33 Location: Barnsley, UK
Posted: Sun Sep 14, 2003 8:04 am Post subject: Arkon Multimedia + Emtac BT |
I have almost what I feel is the perfect configuration with the 3970 running TTN2, Emtac BT GPS and an Arkon CM505 Multimedia mount. However, I could do with some power for the Emtac. The Arkon has a DC output on the side. If I had a cable with a couple of 1.7mm DC connectors at either end, would connecting the Emtac to the Arkon allow it to charge the Emtac? - that would be perfection!
No info with the Arkon to say what the voltage coming out is - just says "DC Out jack on side of cradle lets you charge mobile phone devices".
Can anyone help? |
Eagle Occasional Visitor
Joined: 06/04/2003 23:31:54 Posts: 33 Location: United Kingdom
The output that you refer to, on the Seidio Mount, which I understand is the same as the Arkon, is 5v 0.8 a. I use one of these mounts and charge my EMTAC BT GPS (when required) using this output. See my post on the Seidio Mount under accessories. |
Thanks Eagle, I'll see if I can find that! I received my proclip in the post today, the setup is nearly complete! |
alienrider Occasional Visitor
Joined: 04/04/2003 14:59:59 Posts: 41 Location: United Kingdom
I have the Arkon Multimedia mount and it can charge the ipaq and Emtac (Socket). Beware however, I noticed that my Socket BTGPS ran quite warm when connected to it, and hence only use it when absolutely necessary, I would be interested to hear your views on it once you have given it a try.
B _________________ A difficult problem can be solved more easily by reducing it to the question, "How would Bagpuss handle this?" ;-)
Setup: Garmin 3950LMT + PGPSW CAMS |
