Pocket GPS World :: View topic - Speed warning not working
jimbo09990
PostPosted: Tue Mar 22, 2005 5:48 pm    Post subject: Speed warning not working Reply with quote
I have installed checkPOInt and got it working OK.
I have set up the overlays but I only hear the First and Last warnings. I never hear the warning about the speed limit.
When you assign the wav file to the speed warning tab it plays OK but just not when your on the road!
Any ideas?
James
mossflower
PostPosted: Sun Apr 17, 2005 6:57 pm    Post subject: Reply with quote
I have the same problem and would be interested in any solution you come up with. On my Mc (a "hp 2200 with tomtom nav 3 on it ) I get an auidio warning when first entering a 30mph zone but no other speed zone is yours the same?
mossflower
PostPosted: Wed Apr 27, 2005 12:07 am    Post subject: Reply with quote
i ALSO HAVE THIS PROBLEM i HAVE INSTALLED CHECKPOINT ON 3 MACHINES SO FARFOLLOWING THE SAME PROCEEDURE EACH TIME ON THE FIRST TWO I HAD THE SAME PROBLEM IE ONLY THE 30MPH WARNING BEING ANOUNCED. ON THE LAST MACHINE HOWEVER IT WORKS ON ALL SPEED LIMITS. i AM BAFFALED. A WORK AROUND IS TO REPLACE THE FIRST WARNING WITH THE APROPRIATE SPEED LIMIT NOT IDEAL BUT IT WORKS
CraigAH1
PostPosted: Fri Apr 29, 2005 8:00 pm    Post subject: Reply with quote
I have the same problem. It has worked in the past but I have recently changed the overlay settings to the following
First warning 30 seconds
Final warning 20 seconds
Speed warning 10 seconds and set at the speed limit and a loud warning alert
I was hoping that this would give me 2 normal warnings and a last final load warning if I was over the speed limit (but not if I was within the speed limit.
Since doing this the speed warning has not working over or under the speed limit
Any ideas how to get this to work would be appreciated
CraigAH1
PostPosted: Fri Apr 29, 2005 8:01 pm    Post subject: Reply with quote
Deadly_Jowl
PostPosted: Thu May 05, 2005 3:31 pm    Post subject: Reply with quote
I have the same problem! Is it a bug?
mossflower
PostPosted: Sun May 08, 2005 2:11 pm    Post subject: Reply with quote
i think so. I am hoping when navagator 5 coms out it will work better. Confused
hope springs eternal
xda
PostPosted: Mon May 09, 2005 10:45 am    Post subject: Reply with quote
When TT V5 comes out you won't be able to use CheckPOInt or GPSAssist as V5 won't support third party applications, that is untill TT release the code for third party apps to link in.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
xda
PostPosted: Mon May 09, 2005 10:51 am    Post subject: Reply with quote
If it worked ok on the last one you intalled it on. Was there any difference between the processor speed and available memory between this one and the first two?,
Graham.
Nokia 925 Windows 8
22.044 (24 Apr 24)
