Wizzardoz Regular Visitor
Posted: Sun Feb 21, 2016 4:16 pm Post subject: Garmin keeps switching off |
Have a 2699 which I have now tried to reset to factory settings (erase data). It then gives me a UK screen which I accept. On the next warning screen I press OK and the unit turns off.
Any idea how to solve this please?
Thanks |
sussamb Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Joined: Mar 18, 2011 Posts: 4458 Location: West Sussex
Posted: Sun Feb 21, 2016 5:52 pm Post subject: |
Only thing I can suggest is do another reset. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Sun Feb 21, 2016 7:04 pm Post subject: |
sussamb wrote: | Only thing I can suggest is do another reset. |
Thanks! After about 8 hard resets, it seems to work now. Not sure if it will happen again but time will tell! |
Posted: Sun Feb 21, 2016 9:27 pm Post subject: |
Actually the problem was self-created. I moved the POI directory and contents to the SD card via PC and removed the POI directory on the Garmin. This is what caused the confusion. When I removed the SD card it worked and I thought it was the hard resets. As soon I put the card in, it stopped again - then I realised that this POI directory was the issue.
BTW, installing camera database from here with manual option on the loader, I do not get a choice where I want to put them. ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Sun Feb 21, 2016 10:36 pm Post subject: |
Only option you get is to device or computer.
I install mine to computer then manually copy to my nuvi.
Surprised at your cause. I run a POI folder on both my device and card, and I know of many others that do, without any issue. _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Sun Feb 21, 2016 10:51 pm Post subject: |
You get the option of Device or Computer.
Select Garmin Device.
The next screen gives a drop-down list, so you can select either Device (nuvi 2699 unit ID nnnn) or Memory Card (drive reference letter).
Dales.
Edited 23.2.16 - sorry I originally put Computer instead of Device, as the option to select to get to the SD card. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
Posted: Sun Feb 21, 2016 10:58 pm Post subject: |
Yes I run my Poi's quite happily from my SD card.
But note that these must be the Poi's that have been processed by PoiLoader (ie a .gpi file).
I can imagine that the Garmin might choke if you put the raw Poi data (eg .csv or .gpx files) on the SD card.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
