rogergglass Occasional Visitor
Posted: Tue Nov 30, 2010 5:21 pm Post subject: Start 2 - add POIs? |
Does anyone know if it is possible to download POIs to the Tom Tom start2 other than from TomTom |
Andy_P Pocket GPS Moderator
Posted: Tue Nov 30, 2010 5:34 pm Post subject: |
No, you can't. Sorry, but it's a turkey when it comes out of the box.
But there is a way to add a custom menu which gives you SOME of the missing functions back.
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Nov 30, 2010 7:11 pm Post subject: |
Is there a Navigate To/ POI option in the menu? if so you can add third party POI files from this site as well as many others, simply copy the ov2 and bmp files to the active map folder on the device using Windows Explorer.
What it can't do is "warn when neear POI" although hacking the device to run a custom menu or installing a pre-configured MapSettings.cfg file to the unit should get the warnings working even though the option to set warnings isn't on the device - Mike |
Posted: Tue Nov 30, 2010 9:39 pm Post subject: |
mikealder wrote: | Is there a Navigate To/ POI option in the menu? |
That WILL be there, because there are built-in POIs available.
mikealder wrote: |
What it can't do is "warn when near POI" |
Maybe I'm wrong, but I thought you couldn't actually install third-party POI files either (but p'raps I'm thinking of the 'flagship' Go1000 model instead ) |
rgpritchard Occasional Visitor
Posted: Sat Dec 04, 2010 5:13 pm Post subject: I have a TomTom Start 2 with all the good old menus |
I have just purchased a Tomtom Start 2, what a disapointment, all the
menus that I want are not visable, but they are there on your new
Tomtom, just hidden away ,POI warnings, Loads of journey options, in fact too many to described,
All you have to do is follow these instructions.
1, Create a folder on the Root directory of your Tomtom called
"SdkRegistry" Note upper case and lower case
2, Open Windows Notepad.
3. Copy and paste the text below into your Notepad.
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1| Acceuil|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_AVOID_ROUTE_LINE|
MENUITEM|TASK_MENU_PREFERENCES|"preferences.bmp"|"Préférences"|
MENUITEM|TASK_PAGE2|"next.bmp"|
MENUPAGE|TASK_PAGE2| Se repérer / Itinéraire|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE1|"previous.bmp"|
MENUITEM|TASK_EMPTY|
MENUITEM|TASK_PAGE3|"next.bmp"|
MENUPAGE|TASK_PAGE3| Favoris|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_CHANGE_HOME_LOCATION|
MENUITEM|TASK_PAGE4|"next.bmp"|
MENUPAGE|TASK_PAGE4| POIs|
MENUITEM|TASK_CONFIGURE_POI|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_PAGE1|"next.bmp"|
MENUBLOCK|BLOCK_PREF|BTM_DONE|
MENUPAGE|TASK_PAGE5| Navigation|
MENUITEM|TASK_CONFIRM_DELETE_ROUTE|
MENUITEM|TASK_PAGE6|"next.bmp"|
MENUPAGE|TASK_PAGE6| Cartes|
MENUITEM|TASK_SWITCH_NIGHTVIEW|
MENUITEM|TASK_PAGE5|"previous.bmp"|
MENUITEM|TASK_SET_VOLUME|
MENUITEM|TASK_PAGE7|"next.bmp"|
MENUPAGE|TASK_PAGE7|favoris / POI|
MENUITEM|TASK_PAGE6|"previous.bmp"|
MENUITEM|TASK_PAGE8|"next.bmp"|
MENUPAGE|TASK_PAGE8|Affichage|
MENUITEM|TASK_SET_HIDEMAP|
MENUITEM|TASK_SET_COMPASS|
MENUITEM|TASK_SET_STATUS|
MENUITEM|TASK_PAGE7|"previous.bmp"|
MENUITEM|TASK_SET_NAME_DISPLAY|
MENUITEM|TASK_PAGE9|"next.bmp"|
MENUPAGE|TASK_PAGE9|Navigation|
MENUITEM|TASK_MANAGE_MAPS|
MENUITEM|TASK_SET_TOLL|
MENUITEM|TASK_SET_PLANTYPE|
MENUITEM|TASK_PAGE8|"previous.bmp"|
MENUITEM|TASK_ABOUT|
MENUITEM|TASK_PAGE5|"next.bmp"|
Save this file, in the SdkRegistry folder as Tomtom.mnu
Switch your Tomtom off then back on.
Your Tomtom will look the same, Press the map screen to get the usual
options, such as Change Voice etc, when you press Done, rather than
just going back to the map screen, you will go to all the other menus.
If you decide that you do not want these extra menus, then all you have to do is delete the Tomtom.mnu file that you created, your Tomtom is back
to the same conditionas it was before.
I would love to take the credit for this work, but it's not mine, and sadly I forgot to save the internet address from where I got it from,
The file information above is copied fronm my Tomtom Start 2
Use it and enjoy
Roy |
Posted: Sat Dec 04, 2010 6:38 pm Post subject: Re: I have a TomTom Start 2 with all the good old menus |
rgpritchard wrote: |
I would love to take the credit for this work, but it's not mine, and sadly I forgot to save the internet address from where I got it from, |
Possibly here!
It's certainly been discussed on here. (e.g. TomTom start + SDK mnu allowed?) |
Posted: Sun Dec 05, 2010 6:29 am Post subject: Oops Sorry |
Looks to me like they got this work from the Pocket GPS site, and claimed it as their own.
Still I hope it helps others
The only reason why I looked into this subject, was that I had paid my subscription to Pocket GPS for the Safey Camera database only to discover
that unless you can have PIO warning sounds, the database is all but useless to the average user, I dont know if Pocket GPS warn future subscribers of this ?
ATB
Roy |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Sun Dec 05, 2010 3:56 pm Post subject: Re: Oops Sorry |
rgpritchard wrote: | Looks to me like they got this work from the Pocket GPS site, and claimed it as their own.
ATB
Roy |
From the compatibility chart on the database download page..... Quote: | START and Ease do not offer functionality officially but this can be implemented via a custom menu. Please see the forums for details. |
_________________ Dennis
Two of them are obesiting!! |
andyfras Occasional Visitor
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Posted: Thu Jan 20, 2011 7:31 pm Post subject: |
I've been playing about with the above menu and it seems to ignore the first 4 pages, so I've rewritten it and changed the French bits to English. I added the Change Owner option which allows PIN code implementation.
MENUPAGE|TASK_PAGE1|Main Menu 1 of 4|
MENUPAGE|TASK_PAGE2|Page 2|
MENUPAGE|TASK_PAGE3|Page 3|
MENUPAGE|TASK_PAGE4|Page 4|
MENUPAGE|TASK_PAGE6|Maps|
MENUPAGE|TASK_PAGE7|Favourites / POI|
MENUPAGE|TASK_PAGE8|Settings|
MENUITEM|TASK_ASK_CHANGE_OWNER|
MENUITEM|TASK_PAGE5| |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Thu Jan 20, 2011 8:59 pm Post subject: |
Have you tried the version of my web site.
Just click my sig below then my TT page. It was done for the ONE v4 but may work okay with the Start2 ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
keithwjones Occasional Visitor
![](modules/Forums/images/avatars/89366040246126b7643a6b.jpg)
Posted: Fri Mar 18, 2011 12:35 pm Post subject: |
I am using the code as at the top of the page on a start 1 and it is working.
So I have the odd French word which I can change.
There are two other points:
In the menu when you get the grey arrows one on the left and one on the right they are both pointing to the right. If you pres the one on the left you do go backwards. I am presuming that is previous.bmp, is there a way to change it so that it points to the left.
I can not work out how to change the time on the unit.
Keith |
Posted: Fri Mar 18, 2011 5:43 pm Post subject: |
I could not exactly remember where I got info from to change the menu but it was obviously from this post:
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=136159
My screen is exactly the same as the images so I presume that is how it is - which is not really a problem for me.
So all I really need to know is how to change the time?
Keith |
Posted: Fri Mar 18, 2011 6:08 pm Post subject: |
Now worked out the time. Put Easy menu back change time then put advanced menu back.
Keith |
PhilDot Occasional Visitor
![](modules/Forums/images/avatars/9376139264cf6b4e517b1c.jpg)
Joined: Nov 16, 2010 Posts: 24 Location: London, England
Posted: Thu Apr 07, 2011 8:41 pm Post subject: |
The sdk work around seemed to stop working on my Start (1) with the upgrade to one of the 9.0xx navcores. Has anyone definitely had it workng with a later Navcore? |
Posted: Thu Apr 07, 2011 10:25 pm Post subject: |
Just checked my Start 1:
App 9.053.520930.2
Working with this.
Keith |
