Pocket GPS World :: View topic - Navman S50 3D
Navman S50 3D
boothby
PostPosted: Fri Jun 19, 2009 3:53 pm    Post subject: Navman S50 3D Reply with quote
I've just bought a Navman to replace my Garmin Nuvi 200 and am trying to load the camera database on it.
I have Navdesk running & the Navman connected to the PC.
According to the installation guide on Navdesk there should be a column of 9 options on the L/H side of the screen including one for "Custom POIs".
I only have 4 on my Navdesk Confused - Navman Online/My Maps/Nav Album & Image Search.
Seems to me there is something wrong somewhere. Is it me or the software Embarassed. (may be I ought to have stuck with the Garmin Crying or Very sad. It was a lot simpler, trouble is it doesn't have blue tooth Sad ).
Can any of you good folks help me along the way?
Many thanks
Boothby
boothby
PostPosted: Fri Jun 19, 2009 4:40 pm    Post subject: Navman S50 3D - Navdesk & Custom POIs Reply with quote
I've just found the post from Jan by Ronaar who had the same problem & managed to resolve it.
Mine circumstances are slightly different in that the Satnav is connected via the supplied USB cable but makes no difference to the no of screen options available.
I'm doing on my laptop, (under Win XP), but I can't see that this would make any difference
PaulB2005
PostPosted: Fri Jun 19, 2009 4:45 pm    Post subject: Reply with quote
Have you tried different USB Ports?
boothby
PostPosted: Fri Jun 19, 2009 5:00 pm    Post subject: S50 3D Reply with quote
Good idea, worth a try. I'll have a go on my desktop as well & see what happens.
Thanks Paul
boothby
PostPosted: Fri Jun 19, 2009 5:55 pm    Post subject: Reply with quote
Hi Paul
I have tried it on a different USB port on my laptop without success.
Haven't tried on my desktop yet, but have contacted Navman technical support and it looks as if, from their response, to be a regular problem.
The emailed me back and advised me to close and re-open the Navdesk and check the USB drivers to be installed. They included a MS word document on how to check & install the drivers which has sorted things out so I now have all of the options that should be there.
I would attach the instructions in case anyone else has a similar problem but it doesn't seem to be possible.
If anyone wants a copy of the instructions pm me with an email address & I will send it.
Thanks for your help.
Regards
Boothby
leastsquare
PostPosted: Sun Aug 02, 2009 9:28 pm    Post subject: Reply with quote
Boothby, any chance you can send the doc to check & correct the usb driver install?
cheers
22.062 (12 Jun 24)
