nudda Regular Visitor
Posted: Thu Dec 21, 2006 9:34 pm Post subject: Garmin nuvi mount not very good ! (falls off atleast once) |
Hi all,
got the garmin nuvi and really like it.
however, after putting the mount into the car on a cold start, the mount is put on as best as possible but the whole mount + uni drops after a while when the car warms up. I am sure its because of some expanding/contracting going on in the mount suction cup.
Has anyone else ever experienced this ? Mine falls off atleast once EVERY SINGLE TIME I go on a trip. its getting really annoying now and not to mention dangerous as it drops 5-10 mins into the journey
can someone advise of what to do ?
Thanks  |
Posted: Thu Dec 21, 2006 9:37 pm Post subject: |
... and its not dust (cleaned it thoroughly). Both the glass and mount are ssqueaky clean. |
smargerison Occasional Visitor
Posted: Thu Dec 21, 2006 10:06 pm Post subject: |
Hi, I find that licking my finger and then running this around the suction cup helps it stay on for much longer |
Posted: Thu Dec 21, 2006 10:08 pm Post subject: |
smargerison wrote: | Hi, I find that licking my finger and then running this around the suction cup helps it stay on for much longer |
probably but its disgusting ... i cant do that every time. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Thu Dec 21, 2006 11:04 pm Post subject: |
like you say it's cos the air warms up and expands pushing it away from the window - not a lot you can do really unless you get a dash-mount beanbag thingy: http://www.thegpsstore.com/detail.asp?product_id=GAX10306
not sure of any uk suppliers but they look great  |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Dec 22, 2006 10:13 am Post subject: |
Although they look great, and apparently work very well too, there is a risk it will become a projectile if the vehicle is involved in an accident. Something for any potential purchaser to consider.
The alternative, although not cheap, are the Brodit mounts, used by a number of PGPSW members (including myself). Be prepared for a shock at the price though - but they are said to be the best. |
Posted: Fri Dec 22, 2006 12:28 pm Post subject: |
Maybe but it doesn't fall off!
Maybe try wetting with water, should do the same job if you have it handy. |
bigant1986 Occasional Visitor
Posted: Sun Dec 24, 2006 3:29 pm Post subject: |
you should try picking up your nuvi off the floor in the passenger footwell and gettin it back on the windscreen whilst doin 70+ in the middle lane of the A1! mine did it at least 3-4 times last time i went on a 240 mile journey! |
Pootle Regular Visitor
Posted: Sun Dec 24, 2006 4:20 pm Post subject: |
I always used to have similar probs with my i3. The best solution I found was:
Make sure both surfaces are totally clean, a light smear of spit on the sucker, then put it onto the surface at speed not gently (spoge it on!), now put two fingers either side of the lever and press down until your fingers almost snap! Then with your spare hand flip the lever over.
I use a sticky disc on the dash of my passat by hands free kit. I never remove the mount except in extremely dodgy areas. My i3 mount has been attached to the disc over 2 months a good 4000+ miles now since I last removed it. _________________ -----------------------------------
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
i3, V8, V2.7, WAAS EGNOS.
Audio V2, Simpsons Voice File
Posted: Sun Dec 24, 2006 5:02 pm Post subject: |
Quote: | you should try picking up your nuvi off the floor in the passenger footwell and gettin it back on the windscreen whilst doin 70+ in the middle lane of the A1! mine did it at least 3-4 times last time i went on a 240 mile journey! |
8O 8O 8O |
hass762 Occasional Visitor
Posted: Mon Dec 25, 2006 9:54 pm Post subject: |
I havnt ever used the mount direct on the windscreen, puts the unit to far out of reach.
I have used from day one the round hard mount with the sticky side.
Fix it to a suitable are on your dash and the mount stays on that without any probs.
Clean the surface thouroughly with some spirits ie aftershave or similar.
Be prepared to have a very difficult job of removing it so, make sure it goes on correctly first time.
I have a feeling the amount of pressure it takes to lock the suction cup down doesn't do it much favours when sticking it to the windscreen. ie the weight of the unit will make it come lose quicker.
anyway, that's my view. |
