Vladivar Occasional Visitor
Posted: Tue Jan 24, 2006 11:25 pm Post subject: Anquet and the ipaq |
I have just bought the national parks of great britain for my HP 6515 Ipaq. I can get the maps up no problem, but I cant get the gps system to work within the new Anquet 6 program. I have an internal GPS and the GPS configure within the software asks for 3 things. The type Garmin,magellan or NMEA. I pick NMEA. The baud rate. I use 5600 for the tom tom gps. and the com port 1-10 or unknown. No matter what setting I put it on it says wrong port. Any ideas????
Vladivar |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Wed Feb 22, 2006 8:01 pm Post subject: |
Do you have other mapping product on your PDA?
If they work find out what port is being used and try that.
Phil |
Posted: Fri Mar 17, 2006 3:36 pm Post subject: |
Just in case you are still having problems...
Use NMEA and 4800 baud for the comms options - the prot will depend on your PDA. My TomTom Bluetooth GPS and Dell Axim 51v work on COM7: - but that is how it chose to assign the port.
I used to use a CF GPS card in an iPaq - that used COM4:
But your choice of bitrate for the NMEA device MUST be 4800 - it's a defacto standard to ensure that all navigation equipment (especially marine) can talk to one another.
Phil |
sven1 Regular Visitor
Joined: Jun 26, 2005 Posts: 131 Location: Norwich, U.K
Posted: Mon Sep 18, 2006 4:36 pm Post subject: |
I have similar problems using an Ipaq 4150 and a BT 74S. I have been unable to get Anquet 1.2 or 6.1 working. There is nothing wrong with the receiver or the BT connection as tomtom uses it fine. I have uninstalled tom tom as some have said it can hog the device but still no luck. a scan or entering ports / protocols/ baud rates manually fail to find the device. When tomtom found the receiver it found it on BT serial port 6. Anquet has no BT com port just comm 1-10 (which all find nothing) and something called other that I can't read properly but it crashes when selected. sorry about the ramble but I am at a loss to what to try next.
TIA Jon |
Posted: Thu Oct 26, 2006 3:10 pm Post subject: |
sven1 - have you downloaded the latest version from the Anquet website? It's 6.0.10 at present. Also - when you do the upgrade you need to de-install the PocketAnquet version prior to doing the PPC upgrade.
Perversley - I had no problems with my AXIM X51v , TomTomII GPS and PocketAnquet (other than the original 6.0.0 version used to crash when live track moved of the edge of some maps). I had problems with my older GARMIN GPSII+ and the PC version of Anquet 6 - it was 6.0.8 before these communicated properly.
I assume you have posted a query on the Anquet web site - they have good support staff that are keen to get it working on as many devices as possible. |
Posted: Thu Oct 26, 2006 3:43 pm Post subject: |
sorted now thanks. hard reset of PDA required. Seems to stem from my TT5 being an upgrade from TT3 and the old TT3 GPS driver still being there. |
