Pocket GPS World :: View topic - acer n35 issue....
acer n35 issue....
J4G3D
PostPosted: Tue Jul 12, 2005 1:45 am    Post subject: acer n35 issue.... Reply with quote
my acer n35 does a complete reset and i lose all info and it goes all back to defualt when i SOMETIMES connect the usb connect to pda to pc to charge it. can anyone confirm why this is?
is it a issue with my PDA?
or
is it because im plugging it into a multiple usb hub connecter?(6 port hub) or... should i connect it to my pc directly into a single usb hub and pref a high speed 2.0 one?
your thoughts, suggestions and comments welcome...
lbendlin
PostPosted: Tue Jul 12, 2005 4:45 am    Post subject: Reply with quote
is it a powered hub? does each of the ports deliver the required 500 mA ?
Lutz
TomTom/TeleAtlas NAVTEQ
J4G3D
PostPosted: Tue Jul 12, 2005 6:03 pm    Post subject: Reply with quote
havnt got a clue mate, it was just a cheap mini 4 port usb hub i bought from ebay about a year ago for £5. so if it wasnt a high powered hub is the possibility there for my PDA to completely reset due to this???
lbendlin
PostPosted: Tue Jul 12, 2005 6:40 pm    Post subject: Reply with quote
there's a chance for that. you should avoid running Pocket PCs through unpowered USB hubs.
Lutz
J4G3D
PostPosted: Tue Jul 12, 2005 7:09 pm    Post subject: Reply with quote
ok so i wil buy a new usb hub, what spec should i look out for? high speed 2.0?? i reckon mine is 1.1...
lbendlin
PostPosted: Tue Jul 12, 2005 7:23 pm    Post subject: Reply with quote
speed is not important. It needs to be a powered hub.
Anyway, it is not recommended to connect a Pocket PC through a hub. Why can't you connect it directly? Do you have just one USB port on your PC?
Lutz
J4G3D
PostPosted: Tue Jul 12, 2005 7:33 pm    Post subject: Reply with quote
i am currently running it directly now. i have 4 usb ports on my pc. though i guess i will get a new usb hub. but can someone point me in the right direction say on ebay?
so anyone else confirm the usb hub i was running the pda off may of been the cause of my pda completely resetting and losing all data? just wana be sure it was that TWICE as its a matter of keep the pda or take it back to the shop...
Pc-Mobile
PostPosted: Wed Jul 13, 2005 5:45 am    Post subject: Reply with quote
Avoid using USB hub unless you have to.
It is always best to connect any USB device directly to PC.
Pc-Mobile
http://pc-mobile.net/gps.htm
londonstone
PostPosted: Wed Jul 13, 2005 8:23 am    Post subject: Reply with quote
The problem with cheap USB hubs is that they split the power supply designed to run one USB device into four serparate weaker ones.
Obviously this causes problems with some devices.
However many USB hubs, come with thier own power supply (i.e. you plug them into the mains) so they can boost the juice to the necessary requirements.
Just look for any USB hub that comes with a A/C plug and you should have no problems. Typically they cost about 10- 15 quid in the shops, but you might get lucky on e-bay.
J4G3D
PostPosted: Thu Jul 14, 2005 1:51 am    Post subject: Reply with quote
thanks guys,
so thats what you mean about powered hubs? well mine isnt powered by mains. just straight into USB port.
ok will take your advice and look about.
thanks
ellesborough
PostPosted: Tue Aug 09, 2005 6:28 pm    Post subject: Reply with quote
I have had two N35s that do hard resets when you connect the power lead while it is turned off. Both went back to Amazon for refund.
One was also bad at re-fixing to the satellite when switched off and on again. Seeing them side by side it was clear one was much more inferior to the other.
