s3dbw Regular Visitor
Posted: Tue Mar 22, 2005 9:58 pm Post subject: Seidio or Brodit |
Ok, so I need a speaker mount for an HP 5550 and the choice woulds appear to be between these two makes, Whats the general consensus on which is the better product? |
Darren Frequent Visitor
Posted: Tue Mar 22, 2005 10:47 pm Post subject: |
Brodit. Better quality by a mile. Made to last and wouldn't look out of place in any car. _________________ Darren Griffin |
xda Lifetime Member
Posted: Wed Mar 23, 2005 4:18 am Post subject: |
Darren wrote: | Brodit. Better quality by a mile. Made to last and wouldn't look out of place in any car. |
Having said that you appear to be using a CarComm mount in you LR, how do you rate that against the Brodit?
The reason I ask is that I can't make up my mind which to go for, Brodit do an active mount for the XDA II but don't yet have a PS2 to RJ11 adaptor cable to connect a TT Wired GPS although they say one will be available in a few weeks. CarComm already have a mount for the XDA II with adaptor cable. CarComm mount 5353 and adaptor cable 4744 total £49.00 as apposed to Brodit at £59.99. I suppose I could use the CarComm adaptor with the Brodit assuming the pin outs are the same. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Wed Mar 23, 2005 7:15 am Post subject: |
Any opinion on retailers?
Thanks |
Posted: Wed Mar 23, 2005 8:37 am Post subject: |
xda wrote: | Having said that you appear to be using a CarComm mount in you LR, how do you rate that against the Brodit? |
I use both, Carcomm for the XDAII and Brodit for my 2210. Carcomm lack a built-in speaker amplifier but are otherwise as good as if not marginally better although they have a very small range.
As long as the speaker amp is not required I would go with the Carcomm. I have a Leadtek mouse connected to it via their PS/2 - RJ11 adapter which makes for a very neat install.
FWIW, Brodit's ProClips are much better than Carcomm's Safety Clips and are interchangable. _________________ Darren Griffin |
Posted: Wed Mar 23, 2005 8:39 am Post subject: |
s3dbw wrote: | Any opinion on retailers? |
HandNav are the official UK Brodit retailer, TotalPDA sell the Carcomm range. _________________ Darren Griffin |
xda Lifetime Member
Posted: Wed Mar 23, 2005 10:49 am Post subject: |
Thanks for that Darren, seams the choice is down to if I want a powered mount or not. Do you know if the Brodit is liable to give the same problem as others seem to be having with the XDA II when they use the the Holux C-100 powered mount that seem to interfere with the XDA II's phone. _________________ Graham.
Posted: Wed Mar 23, 2005 11:01 am Post subject: |
Sorry Graham, I couldn't say. I am testing a Herbert Richter (HR) mount solution that does suffer small amounts of interference when using the XDAII so this may well be the case, HR are a German company with German levels of build quality and components, if it affects them then I can only guess that its difficult to shield against. _________________ Darren Griffin |
xda Lifetime Member
Posted: Wed Mar 23, 2005 11:26 am Post subject: |
Darren wrote: | Sorry Graham, I couldn't say. I am testing a Herbert Richter (HR) mount solution that does suffer small amounts of interference when using the XDAII so this may well be the case, HR are a German company with German levels of build quality and components, if it affects them then I can only guess that its difficult to shield against. |
That's ok Darren, I think this interference problem is going to affect all the active/speaker mounts to a more or lesser extent. With an amplifier, Microphone, speaker and phone in very close proximity there is bound to be problems. So I've settled for the CarComm unit. _________________ Graham.
Posted: Wed Mar 23, 2005 11:34 am Post subject: |
Carcomm were showing a PDA amplifier accessory at CeBIT similar to the Qubit PDA Amp I reviewed a while ago. It would be in addition to the cradle but being a remote solution would circumvent the interference issues,
They haven't posted details yet but it could be an excellent solution, it looked very well thought out with ISO connectors to integrate with the car audio. Just another option to consider! _________________ Darren Griffin |
xda Lifetime Member
Posted: Wed Mar 23, 2005 12:17 pm Post subject: |
Thanks again Darren, CarComm plus the PDA Amp when the release it. _________________ Graham.
