Pocket GPS World :: View topic - Fortuna Clip-On Bluetooth GPS and TT2 and Memory Map
stormywhether
PostPosted: Fri Sep 10, 2004 8:06 am    Post subject: Fortuna Clip-On Bluetooth GPS and TT2 and Memory Map Reply with quote
Okay guys, been scouring this forum and working closely with all the tips offered.
Now I'm back to GPS 2.07 I can at least SEE COM port 6 in the GPS setup area of Memory Map.
Trouble is, despite trying all the baud rates I'm still getting a GPS Timeout alert box each time.
Can't get a GPS lock at all on Memory Map. Using an iPaq 4150 here, and outgoing port is definitely 6.
What's the next step? Genuinely flummoxed, and sincerely grateful for any help you could give me.
PostPosted: Fri Sep 10, 2004 1:58 pm    Post subject: Reply with quote
Any chance you accidentially put the receiver into SiRF mode? MM doesn't understand SiRF, only NMEA
CheshireCat
PostPosted: Fri Sep 10, 2004 11:16 pm    Post subject: GPS setup page for MMNav + Fortuna Clip-On Reply with quote
Running MM 4.2.1 build 413 on an iPAQ 4150 with a Fortuna Clip-On.
PocketPC version 4.20.0, build 13252
the GPS setup screen shows
Status OK
Manufacturer > NMEA
Model > [greyed out as you don't have a choice. Begins NMEA 0183...]
Port > COM6: Bluetooth Serial Port
Baud > 38400
[blank] Debug
In Bluetooth Manager, "My Shortcuts" shows ClipOn-BTGPS: SPP slave and "Active Connections" shows ClipOn-BTGPS Generic Serial
There are sometimes problems getting the iPAQ and the Fortuna to talk to each other but these are usually cured by a soft reset on the iPAQ.
At one stage, I had galloping GPS timeouts that made the iPAQ + Fortuna useless. Removing the Fortuna battery for a minute or so cured this.
Hope this helps,
8Ball
PostPosted: Tue Feb 15, 2005 1:03 pm    Post subject: Reply with quote
Are you currently running any Tom Tom software? I have exactly the same problem with exactly the same set-up.
I've been looking around and there appears to be a problem that Tom Tom hogs the GPS conenction even when not running.
The easy way to solve it is to get GPSGate software, but $30 I'm not too fond of that idea.
8Ball
DavidW
PostPosted: Tue Feb 15, 2005 1:44 pm    Post subject: Reply with quote
If you have problems with not being able to use your Bluetooth GPS in other software with TomTom Navigator 2 or 3 installed, upgrade to TomTom GPS 3.07 (and, if you haven't already, and you have Navigator 3, I'd recommend Navigator 3.07 - the final version of Navigator 2 is 2.24).
If you still can't use your Bluetooth GPS in other software, turn off Bluetooth, soft reset, Start Menu, Settings, System tab, Remove Programs. Tap on TomTom ~ GPS, tap Remove, press OK when you're asked to soft reset.
You should then be able to use your third party software and TomTom software.
If the remove operation has removed TomTom GPS, you'll need to reinstall it!
