Pocket GPS World :: View topic - NEW TO GPS AND PDA???
paulie01
PostPosted: Thu Dec 30, 2004 5:20 pm    Post subject: NEW TO GPS AND PDA??? Reply with quote
Hi there,
just aquired a pda (rz1710) and a gps kit for the same.... very new to this is there anything i should know, i have a sirf 2 gps and will be running tomtom and the speed cam software....
cheers guys..
SHADOW
PostPosted: Sun Jan 02, 2005 1:44 am    Post subject: Re: NEW TO GPS AND PDA??? Reply with quote
paulie01 wrote:
Hi there,
cheers guys..
running same system myself..,,advise u to buy bigger sd card as maps that are preinstalled on your sd card use up 100mb...not leaving u a lot to play with...i use a kingston 512mb sd card serial number..0447SG6012H...without any lockup problems atall...hope this helps Wink
paulie01
PostPosted: Sun Jan 02, 2005 7:45 pm    Post subject: Reply with quote
i have got a 512 card, was just asking for any advice or help, i use the safety camera software but for some reason it doesnt show up the red light cameras????
SHADOW
PostPosted: Sun Jan 02, 2005 10:54 pm    Post subject: Reply with quote
..assuming u have dropped the pocket gps uk redlight....bitmap image+bionary+set up info files into your map folder on sd card..u say that it warns you of speed cameras..do u get an audible warning as well???..if yes then u already have checkpoint installed...this should warn u of the uk redlight cameras....have u looked through your tom tom poi listing to see if the redlight files have been uploaded to your pda...if they are there have u enabled them..go to change preferences,go to next screen and touch the maintain poi logo...in her u can add poi,warn when near poi,enable/disable poi......hopefully this will solve your problem..if not im sorry but i am new to this myself and only passing on info to the best of my knowledge....thanx.... Confused
alix776
PostPosted: Sun Jan 02, 2005 11:09 pm    Post subject: Reply with quote
if you have the hp navigation pack then checkpoint wont work with this version of tomtom navigator checkpoint will only work with tomtom navigator 1 2 and 3 and not hp navigaiton pack which i think use different software
device Lumia 950 xl
SHADOW
PostPosted: Sun Jan 02, 2005 11:20 pm    Post subject: Reply with quote
...hi am i right in saying that checkpoint warns you with an audible tone as you approach your chosen poi????if this is the case then it does work on this version as im currently using it...if checkpoint enables something totally different then i apologise for advice given....thanx... Embarassed
SHADOW
PostPosted: Mon Jan 03, 2005 2:37 am    Post subject: Reply with quote
...alix776 it has come to my attention that this version actually contains a poi detection facility to alert you to upcoming camera positions..once u have them saved as a poi category in navigator..it therfore seems this is not checkpoint as such..so yes u was correct in saying checkpoint does not work on this version..but we do get audible warnings for poi's..a thousand apologies.. Not Worthy
SHADOW
PostPosted: Mon Jan 03, 2005 3:00 am    Post subject: Reply with quote
..tr this link http://pocketgpsworld.com/tomtom-go-poi.php that should sort you out.. Thumbs Up
22.063 (19 Jun 24)
