ebbsfleet_gooners Occasional Visitor
Posted: Thu Dec 30, 2004 12:15 pm Post subject: Is my new Navman broken? |
I was experimenting this morning with adding POI’s when I disconnected the usb cable I moved over to the window to enable it to recive a GPS signal which it did but now it does not load up any maps.
Tried resetting and checked that the map data is still on the SD card it gets a GPS signal but just says got to nearest road at the bottom of the screen
Have I broke it
Any thing I can try
Jelster Regular Visitor
Joined: Nov 22, 2004 Posts: 62 Location: West London - on me 'Blade
Posted: Thu Dec 30, 2004 12:23 pm Post subject: |
Ah, I did that today as well.... I reloaded the base map and all seems fine now.
. _________________ Completely lost in the world of GPS
Garmin Nuvi 760
ICN510 & Autocom - CBR900 RR3 |
Posted: Thu Dec 30, 2004 12:46 pm Post subject: |
Managed to get it back by un-ticking all the maps on the map on memory card screen then going back in and ticking all the maps
seems to be ok now. |
wavesportkermit Occasional Visitor
Posted: Sat Jan 08, 2005 10:18 pm Post subject: confused by memory cwrd screen |
HI,
New to navman software, could you please explain what you mean by 'on the map on the "memory card screen" ~ (where is this screen - on the PC or icn?)
confused |
m62-to-hull Occasional Visitor
Posted: Mon Jan 10, 2005 2:35 pm Post subject: Getting ya maps back .... |
I've experienced similar map-loss problems ....shocked at first ...then irritated but now I know what to do.
I found that leaving the unit switched on, taking out my memory card & sliding it back in forced the unit to re-load whatever was on there. The map data returns each time.
The only peculiarities I've not solved are the speed cameras ...the data always loads BUT sometimes the icons aren't visible for one of the camera types. I find the icon recognition a bit hit & miss ...unless its my competence that's hit & miss, of course ! |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon Jan 10, 2005 2:47 pm Post subject: |
M62-to-Hull,
Have you installed the Service Pack for your iCN. This appears to have cured the invisible Custom POI phenomenon, at least for the PiN/PPC version. iCN users have reported the same.... _________________ Tim |
Posted: Mon Jan 10, 2005 2:52 pm Post subject: |
Yes, I believe I did load the service pack ...dated 29 November I think it was. The ISN desktop does that, by check for updates -yes ? |
Posted: Mon Jan 10, 2005 3:27 pm Post subject: |
Yes, with your iCN connected to said desktop, anyway. I don't have an iCN either, otherwise I'd be able to tell you the software version to expect.
Oh well, it was worth a try. Mind you, if you connect your iCN to your PC and look for updates again using the iCN Desktop, it'll tell you if one is available. If two or three of the numbers in the lefthand column show 1 as opposed to 0 then it's definitely updated. _________________ Tim |
Icelus Occasional Visitor
Joined: Jan 05, 2005 Posts: 14 Location: Miami, Fl USA
Posted: Mon Jan 10, 2005 4:44 pm Post subject: |
Here is the information on the software versions for the iCN510:
Un updated iCN to Service Pack 1 shows:
iCN510 Version: v3.01.1008,
English: v3.0.1000,
Built on: 2004-11-22 12:38:48(B),
Core: T-core-v1_16_0039 2004/11/05-14:41:16.
Non updated iCN shows:
ICN510 Version: v3.00.0027,
English: v3.01.00003
Built on: 2004-09-02 12:44:12(B),
Core: T-core-v1_16_0029 2004/09/02-12:44:16.
You can download Sp1 here:
http://www.navmansupport.com/smartst_pro/SmartST_Pro/NavmanUpdates.html |
Posted: Mon Jan 10, 2005 6:14 pm Post subject: Navman update |
Heay, thanks. I thought I'd successfully updated my 510 but with those build numbers and dates, I could see that I hadn't managed. Done it and can already see some of the improvements. I hope map data updates are as easy ...yeah, right ! |
