gripp Regular Visitor
Posted: Mon Dec 06, 2004 4:45 pm Post subject: Mitac 168 sound fix |
To all Mitac 168 owners...
I have just successfully applied the updated wavedev.dll file to my Mitac 168 and it has certainly fixed the bad sound which was clearly audible during the first 2 or 3 seconds of recording/playback. The fix is available at the Mitac website: http://www.mio-tech.be/downloads/default.asp
I remember reading a while back that someone on here had had a bad experience applying this fix, so full backups are a wise precaution before applying it.
All I can say is that it worked for me. _________________ Nokia E65 & TT Nav6 |
bernieeccles Lifetime Member
Joined: Nov 11, 2004 Posts: 32 Location: Huddersfield
Posted: Tue Dec 07, 2004 7:19 pm Post subject: |
How did you do it ?
I have downloaded the file and extracted it and end up with two files.I copied them to my storage card,but then what ?What application uses runs these files ?
Confused ! |
Posted: Wed Dec 08, 2004 10:03 am Post subject: |
There are two CAB files, one for the Mio168 and one for the Mio336 so ensure that you've downloaded the correct one (file size zipped = 30Mb for Mitac 168).
Copy the correct CAB file to your SD card and then double click on the CAB file from within File Explorer which will in effect run the extraction process and load the patch.
It then shows on the list of installed programs meaning that you can fall back to the original file should you wish. _________________ Nokia E65 & TT Nav6 |
Diplo Regular Visitor
Joined: Nov 16, 2004 Posts: 112 Location: Liverpool, UK
Posted: Wed Dec 08, 2004 2:23 pm Post subject: |
Does this work with the Aldi Medion 95000, which is based around the Mio 168? |
Posted: Thu Dec 09, 2004 12:08 am Post subject: |
Sorry, I don't know the answer to that question. _________________ Nokia E65 & TT Nav6 |
Posted: Thu Dec 09, 2004 8:35 pm Post subject: |
I have copied the file after extraction and before extraction to my storage card but when I click on it/them all I get is a message saying that I need to run a suitable application .
What am I doing wrong ? |
Posted: Fri Dec 10, 2004 12:20 am Post subject: |
Do you also have a Mitac168?
If this doesn't work then I assume you've either got the wrong file or it's not compatible with your PDA. _________________ Nokia E65 & TT Nav6 |
Posted: Sat Dec 11, 2004 3:59 pm Post subject: |
Well to be fair it is the medion 95000,but it is a clone of the mitac,so I can't see why it would not work ! |
Posted: Sat Dec 11, 2004 9:26 pm Post subject: |
Why not cantact Medion and ask them? _________________ Nokia E65 & TT Nav6 |
Posted: Mon Dec 13, 2004 12:03 am Post subject: |
I have this irrational fear of spending hours with a telephone stuck to my ear 8O |
