T5YOB Lifetime Member
Posted: Thu Jul 28, 2022 5:29 pm Post subject: Drivesmart 55 POI now showing |
Wondering if anyone could help with why my points of interest I downloaded off this site won't show on my Drivesmart 55 anymore? You know like the little McDonald's, KFC symbols. They used to work fine and the POI file with them all on is still on my nav. |
Kremmen Pocket GPS Verifier
Posted: Fri Jul 29, 2022 5:25 am Post subject: |
I've never used personal POI'S but maybe worth going through all settings. _________________ DashCam:
Viofo A119 V3 |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Fri Jul 29, 2022 7:58 am Post subject: |
Not showing where? Difficult to answer without a bit more detail _________________ Where there's a will ... there's a way. |
Posted: Fri Jul 29, 2022 5:19 pm Post subject: |
sussamb wrote: | Not showing where? Difficult to answer without a bit more detail |
On the errr map on the Sat Nav.
And all POI settings are turned on, nothing has been changed. Wonder if it's from a software update that's stopped them working for what ever reason. All the Speed Camera's icons show fine from the database here. |
Posted: Sat Jul 30, 2022 4:38 am Post subject: |
If you just load the map and scroll around, the speed camera POI's don't show until they become in range while driving.
Maybe other POI'S are the same.
Can you use/find the POI's to navigate to ? _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Jul 30, 2022 6:33 am Post subject: |
T5YOB wrote: | sussamb wrote: | Not showing where? Difficult to answer without a bit more detail |
Well it could have been the map, the POI list, the Up ahead feature ....
I have POIs turned off otherwise they clutter up the map. Check that Settings, Map and vehicles, Map layers, Up ahead is checked.
If it is and you've noticed this change after a software update then a master reset should cure it. This assumes they do actually show when you do a Where to, Categories, Custom POIs? _________________ Where there's a will ... there's a way. |
