Pocket GPS World :: View topic - Speedtrap Alert for Android (Split from CamerAlert Thread re
Goto page Previous  1, 2, 3 ... 27, 28, 29 ... 40, 41, 42  Next
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA)
PostPosted: Mon Jul 26, 2021 6:51 am    Post subject: Reply with quote
I have 2 saved sets of dashcam footage that you can compare with.
The roadworks one has an average speed zone at the start and a variable towards the end.
The other footage has a Redlight camera towards the end that also announces the speed:
** Roadworks Sample **
** Redlight Sample **
They are a tad large but will give an idea of what I'm getting over BT to my headunit.
If you want a specific camera type I have loads in stock.
walkerx
PostPosted: Mon Jul 26, 2021 7:34 am    Post subject: Reply with quote
Change the settings on the app to include the distance and see what it says
Also have it announce your speed after the camera
And see if both these work as they should
PostPosted: Mon Jul 26, 2021 8:32 am    Post subject: Reply with quote
OK
Won't be till next weekend as I only drive to Reading and back weekly.
Long term for me though - Although it is already speaking the speed as per my example. Not sure if distance is a help as my 15 secs means I can see the camera. If you follow Garmins 36 secs then, yes, you would need a countdown or you'd forget.
But, the STA overspeed works well.
williamsf1
PostPosted: Fri Jul 30, 2021 6:40 pm    Post subject: Reply with quote
just updated database and its showing 15788 total poi and
22 active??
database from two weeks ago shows all active.
what does it mean?
thanks
PostPosted: Sat Jul 31, 2021 5:01 am    Post subject: Reply with quote
If you have 2 identical area databases loaded then the second one only shows changes from the first.
Once you have the latest one loaded remove the first one and the latest one camera numbers will change.
williamsf1
PostPosted: Sat Jul 31, 2021 7:24 am    Post subject: Reply with quote
it worked! thanks for your help 👍
brizzle16
PostPosted: Wed Aug 04, 2021 9:32 pm    Post subject: Reply with quote
If I set STA to automatically start the app on Bluetooth connection to my car rather than the service starting the app does not seem to get any gps info as the location doesn't change and the speedo shows a dash. I then have to force close the app in order to allow it to work when manually starting it, otherwise the issue remains.
If I set it to just automatically start the service everything works fine.
Phone is a Samsung Note 9 running Android 10, One UI 2.5. This has always happened since I started using STA.
Anyone elae found the same or got a solution?
PostPosted: Thu Aug 05, 2021 4:01 am    Post subject: Reply with quote
Change the app preference to allow 'location' to always.
The default is 'only when the app is open'
brizzle16
PostPosted: Thu Aug 05, 2021 8:37 am    Post subject: Reply with quote
Location already set to always.
Should mention that it all works fine if I start the app via the icon, it's only when set to start automatically via bluetooth that I get the issue.
PostPosted: Thu Aug 05, 2021 9:23 am    Post subject: Reply with quote
Strange, I've got mine set to open with BT connection and all OK.
What are your settings under BT ?
Huwge
PostPosted: Thu Aug 05, 2021 11:26 am    Post subject: Reply with quote
Does this app' work offline and does it need a separate map app' running or is it standalone?
My mobile is PAYG and I'm looking for an alternative to the PGW database for use in my second car
brizzle16
PostPosted: Thu Aug 05, 2021 11:31 am    Post subject: Reply with quote
BT under STA
Start Application - disabled
Start Alert Service - enabled
Stop Application and Service - enabled
Enable hands-free mode for voice alerts - disabled
BT for Car
Use for call - enabled
Use for Audio - disabled
PostPosted: Thu Aug 05, 2021 2:00 pm    Post subject: Reply with quote
I've got all 4 of mine ticked
Leo_A
PostPosted: Mon Aug 09, 2021 10:11 pm    Post subject: Reply with quote
Hi.
Next STA beta version 1.2.04 (code 93).
New in this version: direct "over-the-air" update of PGPSW database. No longer necessary to download zip file every time.
Newly installed app needs only step 3 to enter credentials.
PostPosted: Tue Aug 10, 2021 7:46 am    Post subject: Reply with quote
Thanks Leo.
STA updating......
All setup and first database downloaded OK.
Q: I left it at weekly during setup and today being Tuesday is not ideal. How do I change it to every Thursday morning ?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA) All times are GMT + 1 Hour
Page 28 of 42
