Kremmen Pocket GPS Verifier
Posted: Mon Jul 26, 2021 6:51 am Post subject: |
I have 2 saved sets of dashcam footage that you can compare with.
The roadworks one has an average speed zone at the start and a variable towards the end.
The other footage has a Redlight camera towards the end that also announces the speed:
** Roadworks Sample **
** Redlight Sample **
They are a tad large but will give an idea of what I'm getting over BT to my headunit.
If you want a specific camera type I have loads in stock. _________________ Satnav:
Car Average MPG :
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 491 Location: South Yorkshire
Posted: Mon Jul 26, 2021 7:34 am Post subject: |
Change the settings on the app to include the distance and see what it says
Also have it announce your speed after the camera
And see if both these work as they should |
Posted: Mon Jul 26, 2021 8:32 am Post subject: |
OK
Won't be till next weekend as I only drive to Reading and back weekly.
Long term for me though - Although it is already speaking the speed as per my example. Not sure if distance is a help as my 15 secs means I can see the camera. If you follow Garmins 36 secs then, yes, you would need a countdown or you'd forget.
But, the STA overspeed works well. _________________ Satnav:
Car Average MPG :
williamsf1 Regular Visitor
Posted: Fri Jul 30, 2021 6:40 pm Post subject: |
just updated database and its showing 15788 total poi and
22 active??
database from two weeks ago shows all active.
what does it mean?
thanks |
Posted: Sat Jul 31, 2021 5:01 am Post subject: |
If you have 2 identical area databases loaded then the second one only shows changes from the first.
Once you have the latest one loaded remove the first one and the latest one camera numbers will change. _________________ Satnav:
Car Average MPG :
Posted: Sat Jul 31, 2021 7:24 am Post subject: |
it worked! thanks for your help 👍 |
brizzle16 Lifetime Member
Posted: Wed Aug 04, 2021 9:32 pm Post subject: |
If I set STA to automatically start the app on Bluetooth connection to my car rather than the service starting the app does not seem to get any gps info as the location doesn't change and the speedo shows a dash. I then have to force close the app in order to allow it to work when manually starting it, otherwise the issue remains.
If I set it to just automatically start the service everything works fine.
Phone is a Samsung Note 9 running Android 10, One UI 2.5. This has always happened since I started using STA.
Anyone elae found the same or got a solution? |
Posted: Thu Aug 05, 2021 4:01 am Post subject: |
Change the app preference to allow 'location' to always.
The default is 'only when the app is open' _________________ Satnav:
Car Average MPG :
Posted: Thu Aug 05, 2021 8:37 am Post subject: |
Kremmen wrote: | Change the app preference to allow 'location' to always.
The default is 'only when the app is open' |
Location already set to always.
Should mention that it all works fine if I start the app via the icon, it's only when set to start automatically via bluetooth that I get the issue. |
Posted: Thu Aug 05, 2021 9:23 am Post subject: |
Strange, I've got mine set to open with BT connection and all OK.
What are your settings under BT ? _________________ Satnav:
Car Average MPG :
Huwge Occasional Visitor
Posted: Thu Aug 05, 2021 11:26 am Post subject: |
Does this app' work offline and does it need a separate map app' running or is it standalone?
My mobile is PAYG and I'm looking for an alternative to the PGW database for use in my second car
Thanks |
Posted: Thu Aug 05, 2021 11:31 am Post subject: |
BT under STA
Start Application - disabled
Start Alert Service - enabled
Stop Application and Service - enabled
Enable hands-free mode for voice alerts - disabled
BT for Car
Use for call - enabled
Use for Audio - disabled |
Posted: Thu Aug 05, 2021 2:00 pm Post subject: |
I've got all 4 of mine ticked _________________ Satnav:
Car Average MPG :
Leo_A Regular Visitor
Posted: Mon Aug 09, 2021 10:11 pm Post subject: |
Hi.
Next STA beta version 1.2.04 (code 93).
New in this version: direct "over-the-air" update of PGPSW database. No longer necessary to download zip file every time.
Newly installed app needs only step 3 to enter credentials. |
Posted: Tue Aug 10, 2021 7:46 am Post subject: |
Thanks Leo.
STA updating......
All setup and first database downloaded OK.
Q: I left it at weekly during setup and today being Tuesday is not ideal. How do I change it to every Thursday morning ? _________________ Satnav:
Car Average MPG :
