berin Occasional Visitor
Posted: Tue Oct 27, 2020 8:10 pm Post subject: No alerts/incorrect alerts Garmin 276cx |
Something weird happening with my Garmin GPSmap 276CX.
I load the UK database with POI loader, express settings - but I'm not alerted to the cameras.
The camera database is in /garmin/poi as uk.gpi
On the device, the database is there under points/proximity. Proximity alarm is set to on.
If I look at an individual camera, on the device under points/extras, then for example E-GATSO11261 show alarm 0.3mi, alarm above 30mph.
Camera E-Mobile17500 shows alarm range 0.4mi, alarm above 40mph.
Any ideas? |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 564 Location: North Devon
Posted: Wed Oct 28, 2020 3:27 am Post subject: Re: No alerts/incorrect alerts Garmin 276cx |
I'm not familiar with the 276CX, but if you built the .GPI file and it had associated audio in a format the 276CX doesn't support, it might do this - though defaulting to a 'bong' is more likely.
I take it that audio in general, does work on the device (my original Zumo 346 was mute from day 1)
(Does it have individual volume controls for different types of audio - a 'Mixer' setting?) |
Kremmen Pocket GPS Verifier
Posted: Wed Oct 28, 2020 4:59 am Post subject: |
Garmin POILoader requires the SOX file to produce spoken alerts using WAV files.
Read my 'spoon feed ' thread in the Garmin area. _________________ DashCam:
Viofo A119 V3 |
Posted: Wed Oct 28, 2020 10:01 am Post subject: Re: No alerts/incorrect alerts Garmin 276cx |
PhilHornby wrote: |
I don't use the audio alerts (I use the device on a motorbike) but my other devices alert via the screen (either in a pop up or on a banner) but I'm not seeing any kind of alert, audio or visual. |
Posted: Wed Oct 28, 2020 3:47 pm Post subject: Re: No alerts/incorrect alerts Garmin 276cx |
berin wrote: | I don't use the audio alerts (I use the device on a motorbike) but my other devices alert via the screen (either in a pop up or on a banner) but I'm not seeing any kind of alert, audio or visual. |
If it's not generating any kind of alert...
perhaps try to create a much simpler .GPI file (just one point, in .CSV format)
Code: |
Format: longitude,latitude,Name,Comment
e.g.
-1.772299,53.622208,TestPoint,TestAlert |
and then use the 'GPS simulator' to simulate rides past the point you've chosen. I'm assuming the 276CX has that feature.
(Something's stirring in my memory, that you need at least 2 points in a .csv file for them to work - but even if true, it was many versions of POILoader ago and may not still apply) |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Wed Oct 28, 2020 3:47 pm Post subject: |
From memory there's a setting to turn on alerts for POIs? Been a while since I've used a Garmin so can't be any more specific than that...
Also if Garmin decides you're too far under the speed alert then it simply won't show anything. |
Posted: Wed Oct 28, 2020 3:48 pm Post subject: |
MaFt wrote: | Also if Garmin decides you're too far under the speed alert then it simply won't show anything. |
He's a biker  |
Posted: Wed Oct 28, 2020 6:49 pm Post subject: |
PhilHornby wrote: | MaFt wrote: | Also if Garmin decides you're too far under the speed alert then it simply won't show anything. |
He's a biker  |
Posted: Wed Oct 28, 2020 6:51 pm Post subject: Re: No alerts/incorrect alerts Garmin 276cx |
PhilHornby wrote: | berin wrote: | I don't use the audio alerts (I use the device on a motorbike) but my other devices alert via the screen (either in a pop up or on a banner) but I'm not seeing any kind of alert, audio or visual. |
Code: |
e.g.
I'm just downloading the PW speed camera database, which is a CSV - I think the just contains the data you mentioned |
