Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... , 75, 76, 77  Next
stuartb
PostPosted: Fri May 06, 2016 2:34 pm    Post subject: Reply with quote
No. Ash stopped supporting it some time back.
There are another couple of programs from Kremen and dales (forgive me if I've attributed incorrectly) which do similar-ish things.
One allows you to have directional warnings (i.e. the audible warning will be different depending on the direction of the camera) and the other does quite a few things but principally allows more control over the warning distance.
You can find them here:-
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=96612&highlight=csv+converter
and
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=91951&highlight=csv+converter
If you don't need these features, then although I agree Ash's Camera Manager was a great, simple way to update, then manual doesn't take long. If you're only updating every three years, a couple more minutes probably won't hurt :-)
Stuart
PostPosted: Fri May 06, 2016 4:22 pm    Post subject: Reply with quote
Once you get the hang of those two programs, it takes minimal effort to transfer the result to your Garmin using POI Loader.
You run the CSV Direction converter. This 'automatically' downloads the Camera Manager3 database (which contains the directional data), unzips it, then converts the filenames to the correct format with the North, South, East and West tags for Kremmen's CSV to GPX Converter. This allows you to filter various cameras and gets rid of the 'duplicate warnings' that the Garmin gives for adjacent cameras, and lots of other stuff.
The latter program's .zip file also contains the necessary .bmp and .wav files, and also includes the correct version of sox.exe required for Gamin/POI Loader to understand .wav files.
About the only thing that's missing (pay attention K) is a button to run POI Loader from the CSV to GPX converter, making the whole setup about three clicks away.
The two progs are brilliant for Garmin owners to get the very best that can be achieved when using Garmin devices.
And why the hell would you only update once every three years when the camera database changes weekly? Rolling Eyes
PostPosted: Fri May 06, 2016 7:05 pm    Post subject: Reply with quote
Keep that POILoader trigger in the queue and remind me when the decoratings finished.
PostPosted: Fri May 06, 2016 7:20 pm    Post subject: Reply with quote
That could be a long time the way you are doing it at the moment. Sanding your fingers to the bone is never a good idea K. Still, as the Barley Pickers say. "Proper job."
willton
PostPosted: Fri Apr 13, 2018 6:35 pm    Post subject: Completed in 3 seconds Reply with quote
Interestingly, tonight I have set Camera Manager to update and it has done it in 3 seconds rather than 10 mins as before. Not sure when i last checked the timing but it might be due to Windows 10 Creator Update a short while ago.
Go Ash!!
mars.1
PostPosted: Wed Jul 03, 2019 3:35 pm    Post subject: Ash10's Camera Manager has stopped working. Reply with quote
I tried to use Ash10's camera manager as normal but i keep being prompted with "Cannot connect to PocketGPSWorld". I have Automatically log in settings set up on the camera manager & I have even logged onto PGPSW manually & it still won't connect. I have switched my internet off & back on again & my internet is working fine. I have even rebooted the camera manager many times but no joy?
PostPosted: Wed Jul 03, 2019 4:00 pm    Post subject: Reply with quote
PGPSW had major server issues a few days ago. I wonder if ?this could be the cause of your problem. When did it last connect successfully
PostPosted: Wed Jul 03, 2019 4:36 pm    Post subject: Reply with quote
When the site went down my Converter had problems launching as one of the first things it does is compares the local database date with the server one. When the site came back so did the Converter launch (something I need to look at).
I don't know how Ash connects but as there are a few things still not working my guess is he used a route in that's now broken, unless it's still working for others.
mars.1
PostPosted: Wed Jul 03, 2019 4:50 pm    Post subject: Reply with quote
M8TJT it last connected successfully at the end of May the last time i used it. The sever problems PGPSW had is probably the issue & Kremmen has said a route in Ash used could now be broken. I wonder if anyone else is having the same problem i have with the camera manager.
PostPosted: Wed Jul 03, 2019 5:00 pm    Post subject: Reply with quote
That will be the key, is it broken across the board.
mars.1
PostPosted: Wed Jul 03, 2019 5:11 pm    Post subject: Reply with quote
If it is a problem across the board Kremmen then Ash10's camera manager is rendered useless.
PostPosted: Wed Jul 03, 2019 5:17 pm    Post subject: Reply with quote
Odd, it should work as it uses the same download method as Kremmen's app...
PostPosted: Wed Jul 03, 2019 5:41 pm    Post subject: Reply with quote
In that case it should work, as I updated my DS61 via the Converter link last Friday, after the site recovery, without issue.
Strange.
mars.1
PostPosted: Wed Jul 03, 2019 7:20 pm    Post subject: Reply with quote
Does anyone else still use Ash10's camera manager & have they used it without problem's since PGPSW sever problems?
BAVC10
PostPosted: Wed Jul 03, 2019 10:56 pm    Post subject: Reply with quote
Yes, I still use Ash10's Camera Manager and it worked on the release today (3/7/19) as usual.
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
Page 76 of 77
