g0tch Regular Visitor
Joined: May 15, 2008 Posts: 115 Location: North Somerset
Posted: Tue Sep 11, 2018 11:05 am Post subject: Full post codes and co-ordinates help please. |
Post codes: why can’t I search for full post codes? The last letter cannot be put in, instead I’m shown road and house numbers that might not be relevant. If I search for TA1 2JY, I can’t put in the Y. Is this how it supposed to be?
Co-ordinates: how do I input co-ordinates from Google maps? I’m ok with the North one, as it is the same amount of digits but the West has more digits in the box and cannot remove them. I.E. 51.013783 -3084453
Please point me in the right direction. I might get to enjoy my Garmin
Best regards, _________________ Tibor
Garmin Drivesmart 61 |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Tue Sep 11, 2018 11:25 am Post subject: |
That post code doesn't appear in the map data, is it a new development?
As for lat/long, there are 3 different formats so ensure you've selected the correct format in Garmin to match the one in Google maps. If you have just ignore the last number if there are too many. _________________ Where there's a will ... there's a way. |
BigJohnD Frequent Visitor
Joined: Aug 26, 2007 Posts: 404 Location: Glannau Mersi, Lloegr
Posted: Tue Sep 11, 2018 1:42 pm Post subject: |
Ah, the opposite to what is normally the problem  _________________ Where there's a will ... there's a way. |
Posted: Tue Sep 11, 2018 1:45 pm Post subject: |
Looks like the opposite of new build - demolition! |
Posted: Tue Sep 11, 2018 1:47 pm Post subject: |
sussamb wrote: | That post code doesn't appear in the map data, is it a new development? |
I don’t think so. In maps and waze, I can input the full post code and will show Parmin Close, Taunton, as does on my laptop
sussamb wrote: | As for lat/long, there are 3 different formats so ensure you've selected the correct format in Garmin to match the one in Google maps. If you have just ignore the last number if there are too many. |
I now have set format to h ddd.dddddd to use Decimal degrees (DD) from Google.
For North (N) I can put in N51.013783, the correct amount of digits.
For West (W) I need to leave in the first two 00s then 3.084453, (W003.084453) which gives the correct amount of digits. This appears to get me to the correct destination. Having to leave in the 0s I didn’t know.
Many thanks for your help!
Kind regards. _________________ Tibor
Posted: Tue Sep 11, 2018 1:49 pm Post subject: |
Does that mean Garmin ahead od everyone else?  _________________ Tibor
Posted: Tue Sep 11, 2018 2:02 pm Post subject: |
Looks like the postcode fell from use in December 2016 and is no longer on the Royal Mail database.
It would appear Garmin are using a current version of the RM database.
Others may be keeping unused postcodes for reference, though what RM do with letters addressed there I don't know. |
Posted: Tue Sep 11, 2018 2:54 pm Post subject: Re: Full post codes and co-ordinates help please. |
g0tch wrote: | Co-ordinates: how do I input co-ordinates from Google maps? I’m ok with the North one, as it is the same amount of digits but the West has more digits in the box and cannot remove them. I.E. 51.013783 -3084453 |
I use the decimal format, e.g. N53.41420° W2.99905° but then I usually use Basecamp to identify the destination then copy it to the Garmin. |
Posted: Tue Sep 11, 2018 3:18 pm Post subject: Re: Full post codes and co-ordinates help please. |
BigJohnD wrote: | I use the decimal format, e.g. N53.41420° W2.99905° but then I usually use Basecamp to identify the destination then copy it to the Garmin. |
I have not been able to identify that format in my Garmin. May be just a Basecamp thing?
Regards, _________________ Tibor
Posted: Tue Sep 11, 2018 4:36 pm Post subject: |
I'm confused, you're both referring to the decimal format  _________________ Where there's a will ... there's a way. |
Posted: Tue Sep 11, 2018 4:52 pm Post subject: Re: Full post codes and co-ordinates help please. |
g0tch wrote: | I have not been able to identify that format in my Garmin. May be just a Basecamp thing?
Regards, |
Set the co-ords' format in Basecamp's Options:
Enter the co-ords here:
