Pocket GPS World :: View topic - Map Update to 2019.20 available
Goto page 1, 2, 3, 4, 5  Next
BAVC10
PostPosted: Wed Jun 06, 2018 6:47 pm    Post subject: Map Update to 2019.20 available Reply with quote
8.03 GB for the full map set
File size changes (for full Europe are as follows)
Gmapprom.img increases from 2,693,552 to 2,286,592
D6210050A.img (secondary file) increases from 2,171,712 to 2,205,888
Junction view files (North and South) increase to 215,627 and 187,272 respectively
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
Dabri
PostPosted: Wed Jun 06, 2018 7:36 pm    Post subject: Reply with quote
Users with gmapdem, beware. This version deletes the gmapdem disc image file (but not the sum file); make sure that you have a backup ready.
Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.90; Samsung A52.
MichaelCahill
PostPosted: Wed Jun 06, 2018 9:35 pm    Post subject: Reply with quote
I think that a previous update also deleted this file. I would have hoped that Garmin would not make the same error twice. Sad
PostPosted: Thu Jun 07, 2018 7:02 am    Post subject: Reply with quote
Very few devices have that file, I suspect those that do are well used to it being deleted. It's a reminder though that we should all back up our devices before we update, I do it for every device and not just my Garmins.
PostPosted: Thu Jun 07, 2018 7:24 am    Post subject: Re: Map Update to 2019.10 available Reply with quote
2 of those are decreases
PostPosted: Fri Jun 08, 2018 2:37 pm    Post subject: Reply with quote
Before I update my 2699 is it safe being as a file is reported as missing ?
PostPosted: Fri Jun 08, 2018 3:54 pm    Post subject: Reply with quote
Yes. Your nuvi doesn't use that file so won't have it.
PostPosted: Fri Jun 08, 2018 4:26 pm    Post subject: Reply with quote
Ta
I did the 2599 earlier so the files are saved for the 2699 = a 20 minute job.
I solved the download size issue a few months ago by installing a new bigger C:/ SSD. No shortage of Gb now.
Chinster1957
PostPosted: Fri Jun 15, 2018 10:28 am    Post subject: Reply with quote
Just updated my 3598 and it didn't delete the gmapdem file. I had it all saved ready to put back but didn't need to.
CDK
PostPosted: Sat Jun 16, 2018 5:20 pm    Post subject: Reply with quote
Just updated my 3598.
Took about half an hour.
Booting takes more than 30s
Front screen finally appears.
Freezes when "Where To" and "Maps" is pressed.
Does not go to the next screen - just hangs.
Nothing happens.
Currently trying to reinstall map via option on Garmin Express.
Any Suggestions, please?
PostPosted: Sat Jun 16, 2018 7:27 pm    Post subject: Reply with quote
If reinstalling doesn't change things then try a master reset.
CDK
PostPosted: Sun Jun 17, 2018 2:49 am    Post subject: Reply with quote
Thanks sussamb, to my great relief the reinstall worked.
However, as MichaelCahill mentions above, in my case the gmapdem disc image file was also missing and I had to copy it from my backup.
Maybe if it is replaced or not depends on which Garmin server the update comes from?
MichaelCahill
PostPosted: Mon Jul 02, 2018 12:14 pm    Post subject: Reply with quote
When I went into Garmin Express to update it, I noticed that a map update was available for my backup Nuvi 760.
So, for anyone with an older machine and who has NT, rather than NTU, maps, your catchup has arrived. Cool
MC
inspiredron
PostPosted: Wed Aug 29, 2018 1:32 am    Post subject: Reply with quote
I updated this evening, not without traumas. Once the maps and new software were installed the unit kept freezing after I had gone through the calibration process. I was asked to accept the massive ELUA but it froze at that point. I had to cold start several times before I was able to proceed.
Then I found I had lost my favourites for the first time in years. Not critical but annoying. I now find that the previous very clear speed limit sign has been replaced by a less distinct rectangle with, subjectively smaller numbers. If it ain't broke then don't fix it!
Grrrrr
BAVC10
PostPosted: Wed Aug 29, 2018 9:32 pm    Post subject: Reply with quote
8.30Gb for the full 2019.20 map set.
Gmapprom.img increases from 2,286,592 to 2,381,952
D6210070A.img (secondary file) increases from 2,205,888 to 2,237,120
Junction view files (North and South) increase to 216,277 and 187,312 respectively
Page 1 of 5
23.015 (29 Jan 25)
