Tomlewis007 Occasional Visitor
Posted: Fri Sep 24, 2004 4:35 pm Post subject: Cassiopeia GPS |
Hello all
I might be getting my hands on a cassiopeia for free (it needs a new battery) i wanted to see if i could make my self up a cheap-ish GPS system with the safty camera POI on it ?
Can i get voice guide on the cassiopeia ?
any feedback would be great.
thanks
-Tom |
Dave Frequent Visitor
Posted: Fri Sep 24, 2004 4:38 pm Post subject: |
Which Casio ? |
Posted: Mon Sep 27, 2004 2:03 pm Post subject: |
I dont know exactly but its one of the square ones, not one of the really old flip style ones. I think its an E something with a 200Mhz CPU ?
I will try to get some more info.
thanks
-TOm |
Posted: Mon Sep 27, 2004 2:20 pm Post subject: |
Goto http://www.pocketgpsworld.com/compareomatic/index.php?TempID=8 and take a look by adding the Casio's and you should see an image of each one and that should tell you which one you have.
There's very limited support now for the older Casio's e.g. EM500, E105, E115, E125. If it's an E200 then it won't be bad, and you should get voice guidance working.
The E125 and below will run TTN2 and below but I'm not sure about TTN3. |
alix776 Pocket GPS Moderator
Posted: Tue Sep 28, 2004 7:07 pm Post subject: |
it might have the same problems as hp jornada 568 when runing make sure you dissale the show poi (points of interest) if your runnig the 2002 version of pocket pc then it should run ok also make sure the receaive all incoming beams is turned off to youll probbably need a wired gps using a y cable and i think a compact flash card for the maps hope this helps you _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed Sep 29, 2004 4:15 pm Post subject: |
Thats great thanks all.
On a side note totally off GPS can the version of Pocket PC be upgraded on PDA's ?
thanks again all
-Tom |
Posted: Wed Sep 29, 2004 5:43 pm Post subject: |
if its running ppc 2002 then yes if not i dont think so _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Wed Sep 29, 2004 9:30 pm Post subject: |
It would also have to be a manufacturer CD upgrade and I don't believe Casio provided any customised upgrades for their PPC's. |
Posted: Tue Oct 05, 2004 9:23 am Post subject: |
Im guessing this is bad news, I now have the Cassiopeia its an E-105 and its running Windows CE
Im guessing i cant get any GPS software for this as most say Pocket PC ?
thanks |
Posted: Wed Oct 06, 2004 8:42 am Post subject: |
It may work, but remember it's a reduced processor speed and lower memory (32mb). You will need to find applications that support the MIPS processor rather than ARM which is the standard now. |
Posted: Wed Oct 06, 2004 9:53 am Post subject: |
i think navigator 1 MAY work with win ce _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
